March 14, 2013, 12:21 |
particleErosion cloudFunction in 2.1.x
Rep Power: 13 |
Has anyone been able to get the particleErosion cloudFunction in the 2.1.x Lagrangian libraries to actually work?
if you want to test, through the following lines in the kinematicCloudProperties file in the hopper example Code:
cloudFunctions { particleErosion { p 2.6; K 2.6; n 1; patches ( walls ); }; } |
March 14, 2013, 18:36 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
October 25, 2013, 11:30 |
SindreO
The past days, i have tried doing erosion analyses in OpenFOAM using a copy-paste of "Cloud functions" you posted below. It does give me a non-zero field output at the end of the job.
Which wear model does this correspond to? Do you have access to any documentation on the wear model? Thank you in advance. Sindre |
erosion, lagrangian, openfoam |
rhoSimpleFoam div(phi,k/K) 2.1.x 2.0.x | wernsen | OpenFOAM Running, Solving & CFD | 9 | February 24, 2015 04:52 |
intallation problems OpenFoam 2.1.x | danny123 | OpenFOAM Installation | 4 | January 30, 2013 07:24 |
Compilation error with OF 2.1.x | GerhardHolzinger | OpenFOAM Installation | 5 | September 18, 2012 10:04 |
interFoam 2.1.x gives wrong results on low Froude numbers | lt.quibbler | OpenFOAM Running, Solving & CFD | 12 | June 14, 2012 09:06 |
Compilation problems OF 2.1.x | ivan_cozza | OpenFOAM Installation | 8 | March 23, 2012 10:31 |
