Flow over 10%bump with icoFoam
Old   March 13, 2013, 09:55
Default Flow over 10%bump with icoFoam
VS
VSass is on a distinguished road
Hey Foamers,
i'm trying to simulate a 3D flow over a bump and i'm a little confused with the boundaries.
I have an inlet,an outlet and a free surface which is parallel to the surface of the bump.
I've used inletOutlet for both inlet and outlet but i don't know which BC to use for the free surface for p and U.
Thanks
VSass is offline   Reply With Quote
Old   March 16, 2013, 21:14
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Maybe this thread:
http://www.cfd-online.com/Forums/ope...interfoam.html
could help you.
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
bump, freesurface, icofoam
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 22:08
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
problem when running icoFoam on a complex shape flow field wendywu OpenFOAM 1 May 21, 2009 00:40
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 06:57
