Manual limiter of velocity doesn't work
Like Tree12Likes
Old   April 24, 2013, 13:45
immortality's Avatar
Ehsan
immortality is on a distinguished road
thanks.
thus if I comment out that coeffs and use a crankNicolson .5 scheme it will be like a rhoPimpleFoam.true?
but I've found it more stable than rhoPimpleFoam even when I use crankNicolson and without coeffs.
whats your opinion about this method?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   April 24, 2013, 14:44
HECKMANN Frédéric
fredo490 is on a distinguished road
if you remove the "localEuler rDeltaT", the coefficients become useless so you actually don't even need to comment them. You can still do it for safety but you also need to check in the code what is the default value (sometimes even you don't declare it, the solver takes a default value by itself).
I also found that it is more stable but I didn't compare the 2 codes. I think only the pressure file has been changed.
fredo490 is offline   Reply With Quote
Old   April 24, 2013, 15:11
Ehsan
these are defaults:
scalar rDeltaTSmoothingCoeff
        pimpleDict.lookupOrDefault<scalar>("rDeltaTSmoothingCoeff", 0.02)
    scalar rDeltaTDampingCoeff
        pimpleDict.lookupOrDefault<scalar>("rDeltaTDampingCoeff", 1.0)
I'm mixed up.so is it possible that solver use default values for modifying rDeltaT even if I use crankNicolson .5 time scheme?
there isn't any p folder in rhoLTSPimpleFoam.it seems it uses same folder of p as rhoPimpleFoam.
Old   April 25, 2013, 05:12
HECKMANN Frédéric
This is a C++ requirement... If you use the solver, you must create the variable and if possible initialize it in case the user made a mistake or forgot it. No matter if you use it or not, the variable must be there ! It is declared in the program so the program creates it.
As a programmer, you always try your best to give a default value to a variable to avoid any hazardous effects. Here the solver gives a default value like any other function does. For example, the k-epsilon model gives default value for the constant but you can use others if you want.
The two variables are used just below there declaration:
    // Limit rate of change of time scale
    // - reduce as much as required
    // - only increase at a fraction of old time scale
    if
        rDeltaTDampingCoeff < 1.0
     && runTime.timeIndex() > runTime.startTimeIndex() + 1
        rDeltaT =
            rDeltaT0
           *max(rDeltaT/rDeltaT0, scalar(1) - rDeltaTDampingCoeff);
        Info<< "Damped flow time scale min/max = "
            << gMin(1/rDeltaT.internalField())
            << ", " << gMax(1/rDeltaT.internalField()) << endl;
and
    if (rDeltaTSmoothingCoeff < 1.0)
        fvc::smooth(rDeltaT, rDeltaTSmoothingCoeff);
And by the way, the localEuler scheme code comments contains:
This scheme should only be used for steady-state computations
using transient codes where local time-stepping is preferably to
under-relaxation for transport consistency reasons.
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
unable to get parabolic velocity profile with pimplefoam houkensjtu OpenFOAM 4 October 8, 2012 05:41
Emergency:UDF for a time dependent parabolic velocity zumaqiong Fluent UDF and Scheme Programming 12 March 25, 2010 13:00
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
