unphysical behaviour in buoyantSimpleFoam at inclined surfaces |
hannes
Rep Power: 13 ![]() |
Hi there,
I wanted to run a case with the buoyantSimpleFoam solver but got some strange behaviour of the flow - at an inclined wall the hot air moves in the direction of gravity. For comparison I ran the same case with a vertical wall and got the expected result. Moreover, running the case with the inclined wall with the buoyantBoussinesqSimpleFoam solver also gives the expected results. - see attached images inclinedWall_Uz2.jpg straightWall_Uz.jpg inclinedWallBoussinesq_Uz2.jpg The boundary conditions were the following: p_rgh internalField uniform 101325; boundaryField { hotWall { type buoyantPressure; value $internalField; } fixedWalls { type buoyantPressure; value $internalField; } } U internalField uniform (0 0 0); boundaryField { hotWall { type fixedValue; value uniform (0 0 0); } fixedWalls { type fixedValue; value uniform (0 0 0); } } k internalField uniform 0.1; boundaryField { hotWall { type compressible::kqRWallFunction; value uniform 0.1; } fixedWalls { type compressible::kqRWallFunction; value uniform 0.1; } } epsilon internalField uniform 0.01; boundaryField { hotWall { type compressible::epsilonWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0.01; } fixedWalls { type compressible::epsilonWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0.01; } } mut internalField uniform 0.01; boundaryField { hotWall { type compressible::epsilonWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0.01; } fixedWalls { type compressible::epsilonWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0.01; } } Can anybody tell me whether this is a bug or my boundary conditions are not suitable? Thanks a lot, Hannes Last edited by hanness; March 12, 2013 at 11:19. Reason: error in bc for k |
Rep Power: 14 ![]() |
Hi Hannes,
this looks really strange. Which schemes did you use? The fluid is an ideal gas? Bye RMF |
hannes
Dear RMF,
yes, the fluid is calculated as ideal gas. The used schemes are as follows: ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss upwind; div(phi,h) Gauss upwind; div(phi,K) Gauss upwind; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,R) Gauss upwind; div(R) Gauss linear; div((muEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default none; laplacian(muEff,U) Gauss linear uncorrected; laplacian((rho*(1|A(U))),p_rgh) Gauss linear uncorrected; laplacian(alphaEff,h) Gauss linear uncorrected; laplacian(DkEff,k) Gauss linear uncorrected; laplacian(DepsilonEff,epsilon) Gauss linear uncorrected; laplacian(DREff,R) Gauss linear uncorrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p_rgh; } anybody any idea? Thanks a lot Hannes |
hannes
thanks to Henry I got the solution:
"Inclining the wall makes the mesh non-orthogonal but you choose an uncorrected laplacian but a corrected snGrad. If you correct for non-orthogonality the flow goes in the expected direction." |
Ehsan
Rep Power: 26 ![]() |
hi Hanness.do we use unCorrected in orthogonal meshes only and for non normal faces(non-orthogonal) use corrected?should both laplacian and snGradSchemes be the same?am i correct?when we use limit?
twoPhaseEulerFoam unphysical behaviour | GerhardHolzinger | OpenFOAM Running, Solving & CFD | 15 | March 4, 2018 22:35 |
twoPhaseEulerFoam - unphysical behaviour | Lydia | OpenFOAM Running, Solving & CFD | 14 | June 14, 2012 03:21 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
Unphysical behaviour in dynamic mesh/vof model | xaero | FLUENT | 0 | April 24, 2011 07:50 |
Unstable behaviour after long period of stablility | plunge11 | FLUENT | 1 | April 6, 2011 09:15 |
