komegaSST model
Old   March 1, 2013, 02:32
Default komegaSST model
stix is on a distinguished road
Hi!
I am new to OpenFOAM and I have to use OpenFOAM for my diploma thesis. I want to compare the results of OpenFOAM with simple examples, which can be calculated by hand. My first example is a straight pipe flow and i already have problems. My geometry is a 1mx1m quadratic tunnel with a length of 20m. I defined all boundary conditions (inlet 5 m/s, outlet pressure=0, wall ). The flow is turbulent and i use the komegaSST model for the turbulence. i simulated the flow with different mesh resolutions (various y+). The y+ values i were 30, 50, 100, 150.
Now the problem is that i calculated the pressure loss analytically and the OpenFOAM results aren't even near the exact results. They are 30% (and for high y+ values even more) away from the exact results.
Could anybody please help me with my problem?
Thanks, Daniel
stix is offline   Reply With Quote
Old   March 4, 2013, 07:22
PLD
Pierre-Luc
PLD is on a distinguished road
You should try with y+ = 1 and Wall Functions :
- kqRWallFunction for k
- omegaWallFunction for omega
- nutLowReWallFunction for nut.
I think this is the best way to use the komegaSST turbulence model.
Regards,
PLD is offline   Reply With Quote
Old   March 4, 2013, 07:31
Originally Posted by PLD View Post
Regards,
Thank you,
but i have a question. I am really new to OpenFOAM. How do i define Wall Functions?
Old   March 4, 2013, 08:26
PLD
Pierre-Luc
In the 0 directory you have files for k, omega and nut. You define the wall functions for your walls in these files. You should read the user guide for more information.
Old   March 4, 2013, 09:12
Ah ok thank you very much.
But my Re-Number is pretty high (10^5). I don't think that low Re function is correct?
Old   March 4, 2013, 09:30
PLD
Pierre-Luc
Actually, when you use a y+ = 1, you use (or at least you should) a Low-Re formulation of the turbulence model. In OF, the difference between Wall functions and the Low-Re formulation is not very clear. You should read this thread for a better understanding :
http://www.cfd-online.com/Forums/ope...-openfoam.html
Let me know if your results are better with y+ = 1.
K - epsilon VS SST turbulence model Maicol Main CFD Forum 0 November 30, 2012 17:25
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 07:19
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 11:27
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 21:51
