How to prescribe fully developed turbulent velocity profile at inlet? |
February 21, 2013, 11:46 |
Rep Power: 13 |
Hi everybody,
While doing a simulation of flow around wall mounted cube, I found in Franjo Juretic Phd thesis that one way to have a fully developed turbulent velocity at the inlet was to do a separate channel flow simulation and then interpolate it onto the inlet using cubic interpolation. You can read more on page 162: http://powerlab.fsb.hr/ped/kturbo/Op...JureticPhD.pdf I want to do so in OpenFoam, so I adapted the geometry of the channel395 tutorial to my case dimensions and got the flow field. The way I understood this suggestion is to take the field at some point in the domain and map it into the inlet of the domain with the cube. I first naively thought that Mapfields could do so but what is the link with cubic interpolation then? Please could you help me with understanding this suggestion? I don t know in fact if I should use the velocity profile at the outlet of channel flow and map it (or interpolate it) at the inlet of my geometry with the cube. Or maybe I am wrong? Also please, how to assure this interpolation in openFoam? Is there a utility for that please? Thank you in advance for your answers ( I really think I need them as I donīt know how to start) Regards, Nore |
February 22, 2013, 10:30 |
Rep Power: 13 |
Does anybody has a clue about how to proceed please?
Thanks again. Nore |
How to export velocity profile and load it as inlet condition | wangy16 | FLUENT | 38 | March 13, 2019 07:43 |
Fully developed flow profile | icfd | Main CFD Forum | 3 | May 20, 2009 23:21 |
problem with velocity inlet profile file | Duncan | FLUENT | 3 | November 21, 2005 08:28 |
inlet velocity profile in Polyflow | srinu | FLUENT | 0 | January 16, 2003 21:25 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
