Unable to get converged solution using SimpleFoam
Old   February 14, 2013, 17:35
Question Unable to get converged solution using SimpleFoam
Reno
jr33 is on a distinguished road
Dear Foamers
I am using following simpleFoam solver ( steady state incompressible laminar flow) : mySimpleFoam.tar.gz ( taken from one of the thread), If I run case_of2 example, output shows converged solution.
When I run same solver on my geometry (micro-scale) , I never see a converged solution message on console even though if I run it for long time. For this case, I noticed a large number for " time step continuation error" in the log file. Please find attached log_file, residual plot and fvscheme files. In para view, I see velocity data range in infinity.
I can run ( time dependent ) pisoFoam solver on my geometry, it works fine.
How to get converged solution?
log file looks like this:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Reading field C
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model laminar
SIMPLE: convergence criteria
field p tolerance 1e-12
field U tolerance 1e-12
field C tolerance 1e-12
field T tolerance 1e-12
field "(k|epsilon|omega)" tolerance 1e-12
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 0.991325, Final residual = 0.000574364, No Iterations 6
smoothSolver: Solving for Uy, Initial residual = 0.990776, Final residual = 0.000629279, No Iterations 6
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.00651658, No Iterations 6
smoothSolver: Solving for C, Initial residual = 1, Final residual = 0.00651644, No Iterations 6
GAMGPCG: Solving for p, Initial residual = 1, Final residual = 0.0370417, No Iterations 2
time step continuity errors : sum local = 3.29775e+06, global = -4175.02, cumulative = -4175.02
ExecutionTime = 0.69 s ClockTime = 1 s
Time = 2
smoothSolver: Solving for Ux, Initial residual = 0.606801, Final residual = 0.0018159, No Iterations 6
smoothSolver: Solving for Uy, Initial residual = 0.593997, Final residual = 0.00171948, No Iterations 6
smoothSolver: Solving for Uz, Initial residual = 0.470896, Final residual = 0.00182848, No Iterations 6
smoothSolver: Solving for C, Initial residual = 0.431325, Final residual = 0.00171857, No Iterations 6
GAMGPCG: Solving for p, Initial residual = 0.999989, Final residual = 0.0555931, No Iterations 3
time step continuity errors : sum local = 3.33152e+06, global = -504.3, cumulative = -4679.32
ExecutionTime = 1.02 s ClockTime = 1 s
Time = 3
smoothSolver: Solving for Ux, Initial residual = 0.399376, Final residual = 0.00112685, No Iterations 6
smoothSolver: Solving for Uy, Initial residual = 0.370886, Final residual = 0.00132803, No Iterations 6
smoothSolver: Solving for Uz, Initial residual = 0.427011, Final residual = 0.00391918, No Iterations 6
smoothSolver: Solving for C, Initial residual = 0.315567, Final residual = 0.00229577, No Iterations 6
GAMGPCG: Solving for p, Initial residual = 0.0266644, Final residual = 0.00241473, No Iterations 3
time step continuity errors : sum local = 2.67906e+06, global = -206.142, cumulative = -4885.46
ExecutionTime = 1.34 s ClockTime = 1 s
Time = 4
smoothSolver: Solving for Ux, Initial residual = 0.270695, Final residual = 0.00133643, No Iterations 6
smoothSolver: Solving for Uy, Initial residual = 0.28929, Final residual = 0.00196956, No Iterations 6
smoothSolver: Solving for Uz, Initial residual = 0.503112, Final residual = 0.000947335, No Iterations 9
smoothSolver: Solving for C, Initial residual = 0.225821, Final residual = 0.000216302, No Iterations 9
GAMGPCG: Solving for p, Initial residual = 0.0116013, Final residual = 0.000575014, No Iterations 3
time step continuity errors : sum local = 1.93363e+06, global = -19.2139, cumulative = -4904.68
ExecutionTime = 1.67 s ClockTime = 2 s
Time = 8026
smoothSolver: Solving for Ux, Initial residual = 0.0189528, Final residual = 4.9705e-05, No Iterations 9
smoothSolver: Solving for Uy, Initial residual = 0.01574, Final residual = 3.78383e-05, No Iterations 9
smoothSolver: Solving for Uz, Initial residual = 0.0155287, Final residual = 3.95947e-05, No Iterations 9
smoothSolver: Solving for C, Initial residual = 0.00179368, Final residual = 9.95282e-06, No Iterations 6
GAMGPCG: Solving for p, Initial residual = 0.0888095, Final residual = 0.00631107, No Iterations 2
time step continuity errors : sum local = 7.15596e+110, global = 9.51894e+108, cumulative = 1.79797e+110
ExecutionTime = 2625.31 s ClockTime = 2625 s
Time = 8027
smoothSolver: Solving for Ux, Initial residual = 0.0189746, Final residual = 4.9723e-05, No Iterations 9
smoothSolver: Solving for Uy, Initial residual = 0.0157005, Final residual = 3.76341e-05, No Iterations 9
smoothSolver: Solving for Uz, Initial residual = 0.0155749, Final residual = 3.96477e-05, No Iterations 9
jr33 is offline   Reply With Quote
Old   February 14, 2013, 17:41
Default fvSolution file attached
Reno
I also get following error at 8000 time step:
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
at mysimpleFoam.C:0
in "/home/jay/OpenFOAM/jay-2.1.1/platforms/linuxGccDPOpt/bin/mysimpleFoam"
#7 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
fvSolution file:
solvers
p
solver GAMG;
tolerance 1e-12;
relTol 0.001;
minIter 5;
maxIter 100;
smoother GaussSeidel; // DIC; //DICGaussSeidel; //FDIC;
nPreSweeps 1;
nPostSweeps 3;
nFinestSweeps 3;
scaleCorrection true;
directSolveCoarsest false;
cacheAgglomeration on;
nCellsInCoarsestLevel 50; // 500
agglomerator faceAreaPair;
mergeLevels 1; // 3
U
solver smoothSolver;
tolerance 1e-12;
relTol 0.01;
nSweeps 3;
maxIter 100;
minIter 10;
C
tolerance 1e-12;
relTol 0.01;
nSweeps 3;
maxIter 100;
minIter 10;
T
tolerance 1e-12;
relTol 0.01;
nSweeps 3;
maxIter 100;
minIter 10;
SIMPLE
nNonOrthogonalCorrectors 0;
residualControl
p 1e-12;
U 1e-12;
C 1e-12;
T 1e-12;
"(k|epsilon|omega)" 1e-12;
relaxationFactors
p 0.3;
U 0.7;
C 0.3;
T 0.3;
fvSchemes file
ddtSchemes
default steadyState;
gradSchemes
default cellLimited Gauss linear 1;
grad(p) cellLimited Gauss linear 1;
grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
div(phi,T) Gauss upwind;
div((nuEff*dev(C(grad(U))))) Gauss linear;
div(phi,C) Gauss upwind;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
laplacian(DT,T) Gauss linear corrected;
laplacian(DT,C) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
Old   February 15, 2013, 04:10
sfigato's Avatar
Marco Longhitano
sfigato is on a distinguished road
Send a message via Skype™ to sfigato
Hi Reno,
in order to get a convergence message it is enough to increase the convergence criteria in your fvSolution file (residual control).
Although your solution seems to be stable, the residual (initial??) is too high. Did you get good results from your computation?
What about the mesh?
Can you post your checkMesh file?
Regards
Marco
sfigato is offline   Reply With Quote
Old   February 15, 2013, 12:38
Reno
Thanks Marco, here is checkMesh file .......
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 177642
internal faces: 163538
cells: 85295
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 85295
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
inlet 108 68 ok (non-closed singly connected)
outlet1 76 50 ok (non-closed singly connected)
outlet2 96 61 ok (non-closed singly connected)
outlet3 96 61 ok (non-closed singly connected)
outlet4 80 53 ok (non-closed singly connected)
walls 13648 6881 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-2.64993e-06 -7.50942e-07 -5.62952e-06) (5.87453e-06 5.84166e-07 4.32026e-06)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (8.18345e-17 -2.59238e-17 -3.34998e-17) OK.
Max cell openness = 1.54844e-16 OK.
Max aspect ratio = 4.3452 OK.
Minumum face area = 4.03065e-17. Maximum face area = 8.01346e-14. Face area magnitudes OK.
Min volume = 1.09442e-25. Max volume = 6.5517e-21. Total volume = 1.42006e-17. Cell volumes OK.
Mesh non-orthogonality Max: 48.3461 average: 15.119
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 3.79094 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Old   February 15, 2013, 14:03
Reno
Originally Posted by sfigato View Post
Hi Reno,
Regards
Marco
How I can check good results from my computation, I can check flow in must equal to flow out: conservation check?
Old   February 16, 2013, 05:43
sfigato's Avatar
Marco Longhitano
Hi Reno,
so..first you must check your results. Are they physical or not?
Your checkMesh looks good (may skewness is a little bit too high)!
As I said before..let the computation run fore more iteration and set the tolerance of all variable equal to zero!
Regards
Marco
P.S.: remeber to remove the residual control (unless your computation may stop too early)
Old   December 12, 2016, 05:48
Smile Large time step continuity error solution
Shrirang
shrirang is on a distinguished road
Hello, Large time step continuity errors occurs when your mesh is not proper or the problem definition is physically incorrect.
Try increasing nonorthogonal correctors in fvsolution file to 2, 5 and 15 keeping view of your grid non orthogonality.
Hope this will help someone.
shrirang is offline   Reply With Quote
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
simpleFoam /water in pipes/ how to obtain and tune the solution? soonic OpenFOAM Running, Solving & CFD 0 March 29, 2012 11:40
Can this solution be regarded as converged? Chander CFX 3 April 3, 2011 07:42
Has the pressure correction method problems? X. Ye Main CFD Forum 17 September 1, 1999 17:14
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
