Turbulence modelling in OpenFoam
Old   February 14, 2013, 11:22
Default Turbulence modelling in OpenFoam
nore5 is on a distinguished road
I find some difficulties defining the right parameters related to turbulence modelling in OpenFoam. in fact, I tried to follow the same steps available in the user guide to set a turbulence model but the result is always the same, my simulations /when I set up a case from scratch/ crash with very high bounding values of turbulence parameters after the first time steps.
How can I learn how to set up an accurate turbulence model please? I can t find a tutorial that focuses on that in particular / a part from user guide/...
Any advice and guidelines are welcome too.
Thanks in advance.
Nore
nore5 is offline   Reply With Quote
Old   February 14, 2013, 13:38
Lieven
Lieven will become famous soon enough
Hi Nore,
Are you using RANS or LES?
Often this type of crash is caused by a bad initial condition or/and by (incompatible) boundary conditions. One 'trick' that can help obtaining better initial conditions is by running potentialFoam first for a number of time steps...
Cheers,
L
Lieven is offline   Reply With Quote
Old   February 14, 2013, 16:31
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
For RANS-based simulations ( and you're sure your boundary conditions are correct), in addition to potentialFoam as an initial condition you can:
  • Use upwind schemes to start with
  • Run the turbulent case with the laminar model first, then turn on turbulence mid simulation
  • use the converged first order result as an initial condition for higher order schemes
These are just some quick tips.
chegdan is offline   Reply With Quote
Old   February 15, 2013, 15:04
Dan and Lieven thank you for these hints.
I will try to apply it to a case and see what happens.
BUT how to make sure the BC are the right ones too please?
Thanks again.
OpenFOAM: LES turbulence model names Ollie OpenFOAM 5 January 7, 2013 11:24
OpenFOAM: LES turbulence model names Ollie Main CFD Forum 1 April 11, 2011 14:03
Homogeneous Turbulence Modelling Zaktatir CFX 0 December 15, 2010 10:37
Recompile turbulence model in OpenFoam qtian OpenFOAM Running, Solving & CFD 7 November 26, 2007 16:51
modelling transition with v2f turbulence model pablo FLUENT 0 August 7, 2006 16:44
