unsteady mixing of three liquids with OpenFOAM |
February 13, 2013, 10:59 |
Mihai Pruna
Rep Power: 16 |
I would like to solve this problem in a time dependent matter.
Which solver is the best? Does anyone have an example case? Thanks! |
February 13, 2013, 14:59 |
Mihai Pruna
Rep Power: 16 |
I guess interMixingFoam and the dambreak tutorial in that folder are a good start?
February 13, 2013, 17:45 |
Mihai Pruna
Rep Power: 16 |
on second thought, interfoam might not work as it can support only two miscible fluids ...
February 14, 2013, 08:12 |
You can try multiphaseInterFoam.
Description: Solver for n incompressible fluids which captures the interfaces and includes surface-tension and contact-angle effects for each phase. Just a correction, interfoam doesnot support miscible liquids. Description: Solver for 2 incompressible, isothermal immiscible fluids using a VOF(volume of fluid) phase-fraction based interface capturing approach. |
May 6, 2013, 07:20 |
Albrecht vBoetticher
Rep Power: 17 |
actually, you will have to extend interMixingFoam to three mixing phases.
Incompressible, miscible mixing of two fluid stream OpenFOAM | Nishchal | OpenFOAM Running, Solving & CFD | 6 | October 9, 2019 07:55 |
how to handle liquids in Openfoam | soonic | OpenFOAM Running, Solving & CFD | 1 | July 30, 2013 07:00 |
Mixing task in OpenFOAM | TomKopp | OpenFOAM Post-Processing | 0 | October 7, 2012 05:37 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Summer School on Numerical Modelling and OpenFOAM | hjasak | OpenFOAM | 5 | October 12, 2008 14:14 |
