October 4, 2016, 22:12 |
#21 |
Rep Power: 13 |
Dear hello77, yes you can use if you want, but not needed. Boussinesq approximation is defined as rho = rho0*(1 - alpha*(T-T0)). where also you can obtain (rho-rho0)/rho.
The effect of Boussinesq approximation can be understood by calculating Richardson (Ri) number. If Ri << 1, the change of density with temperature is very low. Therefore, even you calculate Boussinesq approximation, it will be very small as (rho-rho0)/rho goes to zero. Therefore, you can ignore it. For example, run your case with fully forced convection, after that solve the same problem when Ri = 0.01. You will obtain the same results. |
February 1, 2017, 16:01 |
Forced convection heattransfer
#22 | |
Kim
February 2, 2017, 05:31 |
#23 |
Kim
What BC to be used in the p_rgh file for foced convection?
September 23, 2019, 04:50 |
#24 |
Mohamed Bennour
Rep Power: 7 |
Hi Jubayer, I'm doing my Master thesis on Openfoam could you please upload again the removed files from your dropbox. thank you very much
thermo settings for natural and forced convection | braennstroem | OpenFOAM Running, Solving & CFD | 3 | May 1, 2011 13:33 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 05:58 |
help please with forced convection | lucia | FLUENT | 3 | September 7, 2007 17:59 |
heat convection in a forced fluid | Daniele | COMSOL | 0 | December 20, 2005 09:09 |
giving natural and forced convection bc's | Venu Gopal | FLUENT | 0 | August 29, 2004 11:59 |
