Unexpected behavior for interFoam with fixedGradient pressure BC
Old   January 31, 2013, 05:47
Default Unexpected behavior for interFoam with fixedGradient pressure BC
styleworker is on a distinguished road
for validation of my actual case I'm simulating the interphase flow of the capillary rise tutorial with modified pressure boundary.
In my case, the inlet pressure BC should have a neg pressure gradient. The pressure gradient is higher than the pressure gradient produced by the curvature of the free surface, so that the fluid moves downwards and out of the inlet patch. Basically it does move downwards, but the flow flux is way too low (see case 4 in the appended picture).
I also tested a case with a positive pressure gradient (case 3). As expected the fluid moves upwards, but this case is way slower than the standard capillary rise tutorial (case 2). Actually it should move faster, because there is a additional pressure gradient beside the pressure gradient produced by the interphase.
The applied BC's for pressure are:
    inlet
        type            fixedGradient;
        gradient        uniform -100;
    atmosphere
        type            fixedValue;
        value           uniform 0;
    walls
        type            fixedFluxPressure;
        adjoint         no;
velocity BC's:
inlet
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    atmosphere
    walls
        type            fixedValue;
alpha BC's:
    inlet
        type            inletOutlet;
        value           uniform 1;
        inletValue      uniform 1;
    atmosphere
        type            zeroGradient;
    walls
        type           constantAlphaContactAngle;
        theta0         45;
        limit          gradient;
        value          uniform 0;
styleworker is offline   Reply With Quote
Old   January 31, 2013, 11:34
The solution is actually clear. I assumed before, that the reference pressure is the pressure of the ambient air, which does not make sense :-)
Old   May 20, 2013, 23:56
Nikhil
Nikhilcfd is on a distinguished road
I faced a similar issue with capillary rise in interFOAM. In case 3, (where you applied positive pressure gradient) the fluid should move faster as you explained? Could you please explain how I can specify reference pressure and on what basis?
Whenever I applied positive or negative (or counter) pressure gradient (across the capillary tube/plate), I did not get required rise. When I set interface compression term (Calpha) to zero, the height rise was good in comparison with the analytical solution. For cases where I don't have pressure gradient across the capillary tube (i.e p=0 at both inlet and outlet), I got good results for both Calpha = 1 and 0 (interface was diffuse for c=0 but height rise was good). It appears that the Calpha term is imposing additional pressure on interface for cases with positive/negative pressure gradients across the capillary tubes. Please let me know your suggestions.
Thanks,
NP
Nikhilcfd is offline   Reply With Quote
How to get the total pressure in the UDF? zgzhai Fluent UDF and Scheme Programming 3 September 24, 2018 17:12
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 13:41
Difference between pressure, absolute pressure and Total Pressure shaswat CFX 1 September 6, 2012 07:12
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 07:07
