February 11, 2013, 09:32 |
Unresolved problem and Queries
#21 | |
Himanshu Sharma
Rep Power: 14 |
From other post on the forums (http://www.cfd-online.com/Forums/ope...rintstack.html) i came across checking the mesh by "checkMesh" i did that thing and found few things about my mesh bold ones. Code:
Overall number of cells of each type: hexahedra: 223866 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology wall 21803 21858 ok (non-closed singly connected) inlet 278 300 ok (non-closed singly connected) outlet 493 528 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.0199212 -4.33681e-19 -0.0008) (-0.00992118 0.01 0.0108) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-2.29843e-15 2.69037e-17 -4.91973e-18) OK. Max cell openness = 3.26926e-16 OK. Max aspect ratio = 21.2719 OK. Minumum face area = 1.27927e-10. Maximum face area = 1.16148e-07. Face area magnitudes OK. Min volume = 1.28223e-14. Max volume = 2.27969e-11. Total volume = 1.00065e-06. Cell volumes OK. Mesh non-orthogonality Max: 43.6834 average: 7.57081 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.12467 OK. Coupled point location match (average 0) OK. |
February 12, 2013, 09:08 |
#22 |
Ali Khalifesoltani
Rep Power: 15 |
According to CFL condition, your dt should be less than 1.2e-14 sec, so you should make a coarser mesh. I am not an expert on openFoam but as much as I know if you don't overconstrain the B.Cs there should be no problem in the boundary conditions you defined. I ran your case and worked a little bit on it but no success was observed. I thought that the problem is probably for your Initial Pressure Condition in the domain and it will cause some math. error in the solution but there was no success. I think the first step to solve your problem is to obey the CFL condition(by decreasing dt or making a coarser mesh) and then investigate on the B.Cs. Regards. Ali |
February 13, 2013, 00:43 |
#23 | |
Himanshu Sharma
Rep Power: 14 |
Thanks for Reply I also think that it necessary for defining an interior pressure conditions in side the box since i don't think wit the given velocity inlet the solver is developing the interior pressure field. but then if i specify some interior pressure inside the domain then it will start affecting my inlet boundary conditions hence i am totally in a mess how to make this problem as this is on of my projects in the university.And i will now try to coarse my mesh and then try to implement the boundary condition how it might work.if you find some ways than please do share. Regards Himanshu sharma |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
CG, BICGSTAB(2) : problem with matrix operation and boundary conditions | moomba | Main CFD Forum | 2 | February 17, 2010 04:37 |
Problem with Boundary conditions | Mahiboobswamulu | Main CFD Forum | 10 | August 26, 2003 14:24 |
boundary conditions problem | reinaldo kuhn | Phoenics | 1 | March 27, 2003 12:46 |
