Negative pressures
Old   January 28, 2013, 07:15
Default Negative pressures
Elio Bufi
legione is on a distinguished road
Hi foamers,
I have to simulate the flow in a cylindrical duct (diameter=0.24 mm) . The flow is made by liquid (e.g. water) that is injected in the duct from a cubic capacity at 160 bar and arrives in another cubic capacity at 1.5 bar. The geometry is pretty simple and is shown in the attached image "GEOMETRY". So, I simulate the case with InterPhaseChangeFoam because I want to study the cavitation occurring in the duct. However I obtain high negative pressures , as shown in the figure "p_results". I don't konw how to interpret these values. Are these values relative to a pressure reference value or are they absolute values? In the latter case: how is it possible to obtain negative absolute pressure without a solver crash?
I attach the p_rgh boundary condition in the 0 folder:
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object p_rgh;
dimensions [1 -1 -2 0 0];
internalField uniform 160e5;
boundaryField
inlet
type fixedValue;
value uniform 160e5;
U U;
rho rho;
psi none;
gamma 1;
outlet
type fixedValue;
value uniform 1.5e5;
wall
type zeroGradient;
cyl
type zeroGradient;
frontBack
type empty;
Thank you in advance for your attention.
legione is offline   Reply With Quote
Old   January 28, 2013, 12:04
Eric Robertson
msuaeronautics is on a distinguished road
Your output in Paraview are always relative pressures with the datum being atmospheric (I suppose unless otherwise specified).
msuaeronautics is offline   Reply With Quote
Old   January 29, 2013, 04:08
Elio Bufi
Thank you for tour reply msuaeronautics.
Can you explain me how to set the reference pressure in OpenFoam or Paraview in order to get only positive relative pressures?
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
