where does wall boundary condition is defined?
Old   January 23, 2013, 06:36
Default where does wall boundary condition is defined?
immortality's Avatar
Ehsan
immortality is on a distinguished road
i cant find wall BC in src.where it is defined?
I want to see how its impermeability is defined.
Thanks.
immortality is offline   Reply With Quote
Old   January 23, 2013, 06:42
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Ehsan,
Wall is not a boundary condition, but an attribute to the patch. Please read the third paragraph in my previous post to you again:
http://www.cfd-online.com/Forums/ope...tml#post403260
A patch with the attribute "patch" can easily act as a wall, if you give noslip on velocity and zeroGradient on the pressure.
Furthermore, you keep posting similar questions in a lot of new threads. This will only results in a lot less searchable forum, so please modify your behaviour.
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   January 23, 2013, 07:37
Default how can use a property at a point in groovyBC?
Ehsan
i want to use value of pressure at a point to set a boundary condition.more clear i need to set a p0,T0 boundary condition when shock is reached at the end of the channel.what command shouldp i use at fractionExpression?
Applying Rotational Boundary Condition on Surface with Radial Wall tango711 CFX 16 October 9, 2018 08:01
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
natural convection mehrdadeng CFX 10 February 25, 2011 06:25
Wall boundary condition (a very simple question) safa_c FLUENT 1 August 15, 2010 06:05
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 09:28
