February 9, 2015, 10:43 |
#61 |
Sandeep Menon
Rep Power: 25 |
Hello Giancarlo,
Perhaps you could print out your "T" field after mesh.update() and see if the values are within the range that you expect? I'm looking to see if the field remapping after topology changes is correct. Thanks, Sandeep |
February 9, 2015, 13:28 |
#62 |
Giancarlo
Rep Power: 13 |
Hello Sandeep,
thanks for your reply. I have checked the temperature field after the mesh.update and the remapping seems to work well. I insert what I see from the bash Code:
Create time Create dynamic mesh for time = 0 Selecting dynamicFvMesh dynamicTopoFvMesh Selecting metric Knupp --> FOAM Warning : From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 85 could not load libtetMetrics.so: cannot open shared object file: No such file or directory Selecting motion solver: mesquiteMotionSolver Selecting quality metric: AspectRatioGamma Selecting objective function: LPtoP Selecting optimization algorithm: FeasibleNewton Outer termination criterion (tcOuter) was not found. Using default values. Reading field T Reading transportProperties Reading diffusivity DT Time = 0.001 before mesh update * T gas min/max = 300, 773 ************** QualityAssessor(free only) Summary ************** Evaluating quality for 40521 elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.00071332 1.251984571 1.262627653 2.5725376290.1635946915 ************** QualityAssessor(free only) Summary ************** Evaluating quality for 40521 elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.000839219 1.251709074 1.262370641 2.573260010.1637193572 ~~~ Mesh Quality Statistics ~~~ Min: 0.5325301726 Max: 0.999440912 Mean: 0.8683070914 Cells: 40521 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Topo modifier time: 0.166229 s Bisections :: Total: 0, Surface: 0 Collapses :: Total: 0, Surface: 0 Swaps :: Total: 430, Surface: 3 Mapping time: 0.037745 s Reordering time: 0.038874 s ~~~ No flux correction ~~~ ~~~ Mesh Quality Statistics ~~~ Min: 0.5669694553 Max: 0.999440912 Mean: 0.8671070099 Cells: 40523 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. Mesh topology OK. Boundary openness (5.813326312e-16 -2.317997225e-19 -4.530630939e-19) Threshold = 1e-06 OK. Max cell openness = 2.179222994e-16 OK. Max aspect ratio = 4.19270934 OK. Minumum face area = 7.109358104e-08. Maximum face area = 1.695177569e-06. Face area magnitudes OK. Min volume = 1.202657362e-11. Max volume = 6.654840401e-10. Total volume = 4.185231801e-06. Cell volumes OK. Mesh non-orthogonality Max: 51.15319832 average: 16.46141962 Threshold = 70 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.6017764185 OK. Mesh geometry OK. Mesh OK. after mesh update * T gas min/max = 300, 773 GAMG: Solving for T, Initial residual = 1, Final residual = 2.009590784e-09, No Iterations 6 after compute laplacian * T gas min/max = 277.230632, 773 Best regards Giancarlo |
February 9, 2015, 13:40 |
#63 |
Sandeep Menon
Rep Power: 25 |
This then suggests that you have problems in your solution set up. You should check your schemes and boundary conditions. Since you're solving a laplacian, do you have fixedValue boundary conditions? You might have a saddle-point problem otherwise.
February 9, 2015, 14:00 |
#64 |
Giancarlo
Rep Power: 13 |
Yes, I have fixedValue BC for temperature field:
dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { outlet { type fixedValue; value uniform 773; } } Code:
ddtSchemes { default Euler; } gradSchemes { default cellLimited Gauss linear 1.0; grad(T) cellLimited Gauss linear 1.0; } divSchemes { default Gauss skewCorrected linear; } laplacianSchemes { default Gauss linear corrected; laplacian(DT,T) Gauss linear corrected; } interpolationSchemes { } snGradSchemes { default limited 0.5; } fluxRequired { default no; T ; } |
February 16, 2015, 12:40 |
#65 |
Giancarlo
Rep Power: 13 |
Hello Sandeep,
I worked about the problem that I explained you last week, but I think that it's not a problem of the discretization schemes. I have made a very simple case in order to better explain the discrepancy during the solution of the laplacian equation. My mesh is a box of 16 cells. I move only a face of the box in order to have the restriction of the initial volume. I set the temperature of the domain to 700 (boundary and internal field). Moreover, I compute the temperature laplacian: Code:
fvm::ddt(T) - fvm::laplacian(DT, T) If, I don't move the mesh the temperature is always constant to 700. The solver is able to properly solve the laplacian. On the other hand, if I set the mesh motion, I register no feasible temperature field. (the solution is not bounded to 700). I post the results, after the first iteration: Code:
Time = 0.01 First Time = 0.01 before mesh update * T gas min/max = 700, 700 ************** QualityAssessor(free only) Summary ************** Evaluating quality for 16 elements. This mesh had 16 tetrahedron elements. There were no inverted elements detected. No entities had undefined values for any computed metric. Element Quality Statistics minimum average rms maximum std.dev. 2.31432 3.9077 4.06364 5.36664 1.11494 Number of statistics = 16 Metric = Inverse Mean Ratio Element Quality not based on sample points. ************** QualityAssessor(free only) Summary ************** Evaluating quality for 16 elements. This mesh had 16 tetrahedron elements. There were no inverted elements detected. No entities had undefined values for any computed metric. Element Quality Statistics minimum average rms maximum std.dev. 2.32711 3.90594 4.06299 5.37956 1.11869 Number of statistics = 16 Metric = Inverse Mean Ratio Element Quality not based on sample points. ~~~ Mesh Quality Statistics ~~~ Min: 0.18607 Max: 0.430672 Mean: 0.280001 Cells: 16 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Topo modifier time: 0.000501 s Bisections :: Total: 0, Surface: 0 Collapses :: Total: 0, Surface: 0 Swaps :: Total: 4, Surface: 4 Mapping time: 0.000575 s Reordering time: 9.8e-05 s ~~~ Mesh Quality Statistics ~~~ Min: 0.18607 Max: 0.430672 Mean: 0.280001 Cells: 16 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. Mesh topology OK. Boundary openness (0 0 0) OK. Max cell openness = 1.00066e-16 OK. Max aspect ratio = 20.6157 OK. Minimum face area = 1.40167e-06. Maximum face area = 2.49375e-05. Face area magnitudes OK. Min volume = 1.05712e-09. Max volume = 4.43364e-09. Total volume = 4.9875e-08. Cell volumes OK. Mesh non-orthogonality Max: 80.9498 average: 62.9846 *Number of severely non-orthogonal (> 70 degrees) faces: 8. Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.467541 OK. Mesh geometry OK. Mesh OK. after mesh update * T gas min/max = 700, 700 DICPCG: Solving for T, Initial residual = 1, Final residual = 7.56663e-07, No Iterations 6 after solution * T gas min/max = 698.49, 704.226 Now, I'm working with OF-2.3, but I try to solve the same system with (OF-1.6-ext and OF-3.1-ext) and I have always the same problem. I think that, maybe, not all the mesh fields are updated with the mesh motion. Do you have any suggestion? I attach the test case and solver. Thanks in advance Best regards Giancarlo |
March 11, 2015, 08:23 |
#66 |
Alexander Bartel
Rep Power: 11 |
Hello Sandeep,
I am interested in using dynamicTopoFVmesh, but can't pull it from github for OF2.3.0 . Perhaps it is on purpose because of some updates of the files or something like that. In that case don't mind this post. If i try to pull dynamicTopoFVmesh for OF2.3.x I get the Version for OF-ext instead. By clicking the link for OF2.3.x a pretty cool Tatooine error 404 shows. (for everybody who has 2 Seconds time here is the link https://github.com/smenon/dynamicTop...new/Port-2.3.x ) kind regards Alex |
March 11, 2015, 08:48 |
#67 |
Sandeep Menon
Rep Power: 25 |
You need to do this to switch to the Port-2.3.x branch after a git clone:
git checkout Port-2.3.x |
March 11, 2015, 09:03 |
#68 | |
Alexander Bartel
Rep Power: 11 |
Thanks for the fast reply.
With your hint I tried the clone command with following option. Quote:
kind regards Alex |
March 12, 2015, 06:33 |
#69 | |
Rep Power: 15 |
Best regards, Antonio |
April 13, 2015, 09:29 |
#70 |
Sandeep Menon
Rep Power: 25 |
Hello Antonio,
Could you use this option in mesquiteMotionSolver (under mesquiteOptions in constant/dynamicMeshDict): Code:
usePointDisplacement yes; |
June 12, 2015, 04:33 |
#71 | |
Matthias Neben
Rep Power: 14 |
Hello Sandeep, actually I'm playing around with different mesh motion methods in OpenFOAM. Therefore I've created a simple test case, which is a carman flow around a moving cylinder (see attachment) At first I've run moveDynamicMesh without boundary motion to optimize the mesh (as you recommended), afterwards I enabled the boundary motion and run the simulation with pimpleDyMFoam (adjustTimeStep enabled). Regarding to your post this will fail due to the adjustable time step and the way you've implemented the mesh motion. Thats why I changed "refPoints_ += dPointField" to "refPoints_ = dPointField". But with both versions of the dynamicTopoFvMesh library (of31 and your git version) I get a floating point exception. Is there any other way to fix this except the timeVaryingDisplacement patchField? How can I achieve the full range of available patchFields? Best regards Matthias |
February 4, 2016, 12:32 |
#72 |
Giancarlo
Rep Power: 13 |
Dear all,
I'm a Ph.D. student of chemical Enginnering. The aim of my work is to develop a solver within the OpenFOAM framework for the combustion of spherical/cylindrical particle of biomass. To reach this object I have to introduce a moving mesh in order to allow the shrinking of the particle. I'm currently working with the dynamicTopoFvMesh library developed by Sandeep Menon and it works very good for a sphere, but I have several problems for the cylinder. For sake of clarity, I attach you the picture of my mesh at time 0. I have three boundary patch (inlet, outlet, lateralSurface) and I need to move, at the same time, all the point of each boundary with a prefix velocity along the face normal direction. As you can see from the second picture that I've attached, the mesh does not evolve with a uniform shrinking in both directions (axial and radial), but the border points, that belong at the same time to two different patches, seem to move with different velocity. My question is, Is it possible to perform this kind of mesh shrinking with this library? I attach you my case, I use moveDynamicMesh as solver. Thanks in advance Giancarlo time0.jpg time2.jpg cylinder.zip |
February 6, 2016, 05:54 |
#73 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer @Giancarlo_IngChimico: I haven't done the math nor tested the case yet, but I'm guessing that the problem is that the sides must be defined to move at 50% the speed of the cylinder.
I suggest that you do a test in ParaView and use the Transform filter to scale down to 0.5 on all directions and then check what were the distance changes that occurred on each surface. By the way, which OpenFOAM version are you using?
February 6, 2016, 09:07 |
#74 | |
Giancarlo
Rep Power: 13 |
Dear Bruno,
Currently I'm using openFoam 2.3.x. Thanks for your help. In my opinion the border points are update twice depending the patch order in the fixedValuePatches subDict. It leads, for some reason, a no uniform mesh motion in both radial and axial coordinates. Quote:
February 7, 2016, 16:26 |
#75 | ||
Bruno Santos
Rep Power: 128 |
Hi Giancarlo,
I've tried to run your case with the following software stack:
The first suspect is the "toPoints" function: http://openfoamwiki.net/index.php/Co...s_are_defined: Quote:
This can easily occur, because OpenFOAM's main calculations are done on the faces and cells. And since these points on the edges are common to 2 boundaries and not only one, it currently has no other way to assign dedicated boundary conditions for a group of points. Therefore, you will need to do specific calculations for the points on the edges of the cylinder... although I haven't really thought about how that can be done with GroovyBC A quick thinking about it leads me to believe that you can use "inline-if" conditions for defining how calculations are done based on specific conditions. And those conditions you can calculate only for the final boundary. Hopefully you can draw ideas from here: https://openfoamwiki.net/index.php/C...Usage_Examples The other possibility would be to rely on pointSets to manipulate specific point groups and assign dedicated point conditions to them. Best regards, Bruno
February 9, 2016, 14:31 |
#76 |
Giancarlo
Rep Power: 13 |
Dear Bruno,
thanks again for your help. Today I've fixed my problem. dPointField defined in the file mesquiteMotionSolver.C is a pointField where all points displacement are stored. This field doesn't take into account multiple displacement of border points but is being overridden by the final boundary condition that, in my case, is done on "lateralSurface" patch. Adding multiple movements (radial and axial) of the border points in the dPointField , I've fixed my problem. Currently I can mange shrinking of my cylinder both in radial and axial directions. Nevertheless, I have another problem with the surface smoothing. Fist of all, I tried the mesh motion specifying only the outlet and inlet patches in the slipPatches subDict, as follow. HTML Code:
slipPatches { outlet; inlet; } In the second test, I perform the mesh motion with the following slipPatches subDict HTML Code:
slipPatches { lateralSurface; } At the end, I added all my patches in the slipPatches subDict HTML Code:
slipPatches { inlet; outlet lateralSurface; } In other words, it seems the dynamicTopoFvMesh has a bug in multiple patches smoothing. Do you have any idea about these strange behavior? Thanks again Giancarlo one.jpg two.jpg three.jpg |
March 28, 2016, 11:43 |
#77 |
Bruno Santos
Rep Power: 128 |
Hi Giancarlo,
Sorry for the late reply, but only today did I finally manage to take a better look into your question. If my memory doesn't fail me, the "slip patches" feature is for defining the patches that allow the mesh to slide along those patches. For example, attached are two images from OpenFOAM's tutorial case "mesh/moveDynamicMesh/SnakeRiverCanyon", where:
This was possible in this case, because these 4 patches have strict normal definitions that allow the calculations to be performed properly. But in your case, dynamicTopoFvMesh is trying to deduce the normal directions automatically, but since all directions are changing simultaneously, it's not able to know for certain which side is up, because everything is changing. I don't know if you've figured out how to solve these issues, but I believe that the trick is to use a boundary condition that uses the original position as a reference for all other iterations. But this will likely require coding said boundary condition. Best regards, Bruno |
May 13, 2016, 04:13 |
#78 |
Arne
Rep Power: 12 |
Hi all,
I am trying to use dynamicTopoFvMesh to refine a mesh (tets) around a surface in a VOF method with or without the mesquite smoother. Does anybody have a testcase where this is done in a small scale application? At the moment I am trying figure out what the correct settings in the dynamicMeshDict are. However, I am not experinced with the tool and I dont have a runing test case and the default setting seem not to work. Therefore, it is a lot of try and error. If anybody has experince with the field refinement tools of dynamicTopoFvMesh and or a testcase. I would be glad about some input. Best Arne |
November 18, 2018, 14:09 |
#79 | |
daron ciyakian
Rep Power: 9 |
Hello Bruno and Sandeep,
did you figure out the 6dof problem in this 'volvmov-topo' case sincerely daron Quote:
December 30, 2018, 16:06 |
#80 |
Bruno Santos
Rep Power: 128 |
Quick answer: No.
Depending on what you want to do, perhaps it's best that you look into the Overset Mesh feature in OpenFOAM.com (not OpenFOAM.org which doesn't have this feature yet ).
Questions about modeling of a reservoir | hwangpo | CFX | 7 | October 30, 2012 21:46 |
possible interview questions | atturh | Main CFD Forum | 1 | February 21, 2012 08:53 |
Interview Questions | Carna | FLUENT | 0 | December 26, 2011 04:35 |
NACA0012 Validation Case Questions | ozzythewise | Main CFD Forum | 3 | August 3, 2010 14:39 |
Questions about CFD | Lebeau alexandre | Main CFD Forum | 1 | April 6, 1999 14:23 |
