how to draw velocity with direction in paraView? |
January 5, 2013, 12:55 |
Ehsan
Rep Power: 27 |
hi all
in my case velocity is directed through positive or negative x-axis .then I want to draw the velocity with its sign.how can i have a figure of velocity over time at a certain point with its true direction not only its magnitude.is it possible with paraView or the data should extract and plot separately? thanks a lot. |
January 5, 2013, 19:34 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
January 6, 2013, 03:32 |
Ehsan
Rep Power: 27 |
thank you very much dear bernard.i'll test it.
January 7, 2013, 12:11 |
Ehsan
Rep Power: 27 |
it works when showing x-velocity distribution.but when I want to draw the time trace at a given poit it draws U(Magnitude)only not x-velocity magnitude.
January 7, 2013, 15:38 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Don't use that time-trace. Usually (for line-plots) there are 4 Options: magnitude and the components. Manitude is selected. The other 3 are not.
January 7, 2013, 16:26 |
Ehsan
Rep Power: 27 |
thanks.i drew that.after select the point and plot over time,U0 should be selected.thanks for the clue.
Paraview - 2d vector glyphs colored by vector direction & magnitude | newOFuser | OpenFOAM | 2 | March 11, 2017 14:51 |
Plotting the velocity profile in normal direction along a curved surface | StSchiff | OpenFOAM | 0 | December 1, 2011 06:01 |
Fieldfunction Velocity (i) Direction | eRzBeNgEl | STAR-CCM+ | 1 | September 19, 2011 20:06 |
problem defining inlet velocity direction | salman | FLUENT | 3 | January 3, 2007 12:34 |
Buy software for draw vector velocity | Yassin | FLUENT | 0 | January 18, 2006 12:35 |
