divergence in final runs
Old   December 30, 2012, 12:19
Default divergence in final runs
immortality's Avatar
Ehsan
immortality is on a distinguished road
whats the cause of this error?any idea is appreciated!
Time = 0.002893261
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for Ux, Initial residual = 1.20205e-05, Final residual = 7.24706e-17, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 4.37012e-05, Final residual = 3.47885e-17, No Iterations 3
diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for e, Initial residual = 4.885e-06, Final residual = 3.98381e-15, No Iterations 3
smoothSolver: Solving for omega, Initial residual = 0.000214027, Final residual = 2.13867e-13, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.00106578, Final residual = 6.62792e-12, No Iterations 4
bounding k, min: -410.666 max: 99697.4 average: 94.6461
ExecutionTime = 1774.61 s ClockTime = 1778 s
Mean and max Courant Numbers = 0.00838509 0.049984
deltaT = 3.77514e-09
Time = 0.002893265
smoothSolver: Solving for Ux, Initial residual = 1.18995e-05, Final residual = 7.03262e-17, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 4.34716e-05, Final residual = 3.62478e-17, No Iterations 3
smoothSolver: Solving for e, Initial residual = 4.86151e-06, Final residual = 3.97862e-15, No Iterations 3
smoothSolver: Solving for omega, Initial residual = 0.000217299, Final residual = 2.25811e-13, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.00105619, Final residual = 6.58212e-12, No Iterations 4
bounding k, min: -3.82118 max: 99683.7 average: 94.6797
ExecutionTime = 1775.08 s ClockTime = 1779 s
Mean and max Courant Numbers = 0.00838509 0.0499841
Time = 0.002893269
smoothSolver: Solving for Ux, Initial residual = 1.17987e-05, Final residual = 7.32552e-17, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 4.32491e-05, Final residual = 3.62977e-17, No Iterations 3
smoothSolver: Solving for e, Initial residual = 4.84299e-06, Final residual = 4.00826e-15, No Iterations 3
smoothSolver: Solving for omega, Initial residual = 0.00021886, Final residual = 2.20562e-13, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.00104497, Final residual = 6.44333e-12, No Iterations 4
bounding k, min: -443.119 max: 99668.1 average: 94.4821
ExecutionTime = 1775.55 s ClockTime = 1779 s
Mean and max Courant Numbers = 0.00838509 0.0499842
Time = 0.002893273
smoothSolver: Solving for Ux, Initial residual = 1.17082e-05, Final residual = 7.57675e-17, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 4.30538e-05, Final residual = 3.69657e-17, No Iterations 3
smoothSolver: Solving for e, Initial residual = 4.82709e-06, Final residual = 3.97062e-15, No Iterations 3
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 69.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::T(double, double, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const) const in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#3 Foam::ePsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::ePsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::correct() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/rhoCentralFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
thesis@thesis-X58A-UD7:~/Desktop/method_4_2_2(revised)$ paraFoam
created temporary 'method_4_2_2(revised).OpenFOAM'
/opt/openfoam210/bin/paraFoam: 1: Syntax error: "(" unexpected
immortality is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
