Mesquite - Adaptive mesh refinement / coarsening?
Like Tree16Likes
Old   January 14, 2014, 12:17
joegi
joegi.geo is on a distinguished road
Well is a way way way much slower, probably 5 times. In any case, all my previous cases are not working fine. At the moment I am playing with the length scales to see if I find the right values.
Regards,
Joel
joegi.geo is offline   Reply With Quote
Old   January 14, 2014, 13:23
olivier Skurtys
olivier_au_chili is on a distinguished road
Dear Sandeep:
I have run different cases on 4 processors. I have the same problem.
First: dynamicTopoFvMesh run well
but after various time steps > 200, I have this error
 ~~~ Mesh Quality Statistics ~~~
 Min: 0.551996
 Max: 0.999803
 Mean: 0.900042
 Cells: 386866
 Topo modifier time: 1.29494 s
 Bisections :: Total: 0, Surface: 0
 Collapses  :: Total: 0, Surface: 0
 Swaps      :: Total: 3, Surface: 0
 Mapping time: 1.1e-05 s
[manjaro:04482] *** Process received signal ***
[manjaro:04482] Signal: Floating point exception (8)
[manjaro:04482] Signal code:  (-6)
[manjaro:04482] Failing at address: 0x3e800001182
[manjaro:04482] [ 0] /usr/lib/libc.so.6(+0x35390) [0x7faf21a21390]
[manjaro:04482] [ 1] /usr/lib/libc.so.6(gsignal+0x39) [0x7faf21a21319]
[manjaro:04482] [ 2] /usr/lib/libc.so.6(+0x35390) [0x7faf21a21390]
[manjaro:04482] [ 3] /home/olivier/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/libfiniteVolume.so(_ZNK4Foam19coupledFvPatchFieldINS_6TensorIdEEE5writeERNS_7OstreamE+0x122) [0x7faf2494d962]
[manjaro:04482] [ 4] /home/olivier/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/libfiniteVolume.so(_ZN4FoamlsINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEERNS_7OstreamES6_RKNS_14GeometricFieldIT_T0_T1_EE+0x15a) [0x7faf249d763a]
[manjaro:04482] [ 5] /home/olivier/OpenFOAM/olivier-1.6-ext/lib/linux64Gcc46DPOpt/libdynamicTopoFvMesh.so(_ZNK4Foam11coupledInfoINS_17dynamicTopoFvMeshEE4sendINS_14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEEEEvRKNS_4ListINS_4wordEEERKSB_RKNSA_IiEERNS_8OSstreamE+0x88) [0x7faf1411f078]
[manjaro:04482] [ 6] /home/olivier/OpenFOAM/olivier-1.6-ext/lib/linux64Gcc46DPOpt/libdynamicTopoFvMesh.so(_ZN4Foam17dynamicTopoFvMesh18initFieldTransfersERNS_4ListINS_4wordEEERNS1_IS3_EERNS1_INS1_IcEEEES9_+0x8c8) [0x7faf140ba9b8]
[manjaro:04482] [ 7] /home/olivier/OpenFOAM/olivier-1.6-ext/lib/linux64Gcc46DPOpt/libdynamicTopoFvMesh.so(_ZN4Foam17dynamicTopoFvMesh9resetMeshEv+0x468) [0x7faf13ff82a8]
[manjaro:04482] [ 8] /home/olivier/OpenFOAM/olivier-1.6-ext/lib/linux64Gcc46DPOpt/libdynamicTopoFvMesh.so(_ZN4Foam17dynamicTopoFvMesh6updateEv+0x1ae) [0x7faf13ffaf5e]
[manjaro:04482] [ 9] sixDOFFoam() [0x419632]
[manjaro:04482] [10] /usr/lib/libc.so.6(__libc_start_main+0xf5) [0x7faf21a0db05]
[manjaro:04482] [11] sixDOFFoam() [0x41d239]
[manjaro:04482] *** End of error message ***
mpirun noticed that process rank 1 with PID 4482 on node manjaro exited on signal 8 (Floating point exception).
I will attempt to run with debug mode, to obtain more details.
Regards
Olivier
olivier_au_chili is offline   Reply With Quote
Old   January 16, 2014, 05:30
olivier Skurtys
Dear Sandeep
I tested your latest version (01/15) in debug mode: fatal error: cells already calculated. When I run on one processor I have not this error.
[0]  Mapping Faces: 267
[0]  Mapping Cells: 228
[0]  Load starts: 4(0 66 133 200)
[0]  Load sizes: 4(66 67 67 67)
[0]  Load starts: 4(0 57 114 171)
[0]  Load sizes: 4{57}
[1]  Mapping Faces: 55
[1]  Mapping Cells: 30
[1]  Load starts: 4(0 13 27 41)
[1]  Load sizes: 4(13 14 14 14)
[1]  Load starts: 4(0 7 15 23)
[1]  Load sizes: 4(7 8 8 7)
[manjaro:04287] *** Process received signal ***
[manjaro:04287] Signal: Segmentation fault (11)
[manjaro:04287] Signal code:  (-6)
[manjaro:04287] Failing at address: 0x3e8000010bf
[2]  Mapping Faces: 16
[2]  Mapping Cells: 8
[2]  Load starts: 4(0 4 8 12)
[2]  Load sizes: 4{4}
[2]  Load starts: 4(0 2 4 6)
[2]  Load sizes: 4{2}
[3]  Mapping Faces: 87
[3]  Mapping Cells: 66
[3]  Load starts: 4(0 21 43 65)
[3]  Load sizes: 4(21 22 22 22)
[3]  Load starts: 4(0 16 33 50)
[3]  Load sizes: 4(16 17 17 16)
*** Error in `sixDOFFoam': double free or corruption (fasttop): 0x0000000001daab60 ***
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3] cells already calculated
[3]
[3]     From function primitiveMesh::calcCells() const
[manjaro:04290] *** Process received signal ***
[3]     in file meshes/primitiveMesh/primitiveMeshCells.C at line 114.
[3]
FOAM parallel run aborting
[3]
[manjaro:04290] Signal: Segmentation fault (11)
[manjaro:04290] Signal code:  (-6)
[manjaro:04290] Failing at address: 0x3e8000010c2
[manjaro:04289] *** Process received signal ***
[manjaro:04289] Signal: Segmentation fault (11)
[manjaro:04289] Signal code:  (-6)
[manjaro:04289] Failing at address: 0x3e8000010c1
[manjaro:04289] [ 0] /usr/lib/libc.so.6(+0x35390) [0x7f792029a390]
[manjaro:04289] [ 1] /usr/lib/libc.so.6(gsignal+0x39) [0x7f792029a319]
[manjaro:04289] [ 2] /usr/lib/libc.so.6(+0x35390) [0x7f792029a390]
[manjaro:04289] [ 3] /home/olivier/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/libOpenFOAM.so(_ZN4Foam16invertManyToManyINS_4ListIiEES2_EEviRKNS_5UListIT_EERNS1_IT0_EE+0x66) [0x7f79213d6736]
[manjaro:04289] [ 4] /home/olivier/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/libOpenFOAM.so(_ZNK4Foam13primitiveMesh10cellPointsEv+0x7f) [0x7f79213da99f]
[manjaro:04289] [ 5] /home/olivier/OpenFOAM/olivier-1.6-ext/lib/linux64Gcc46DPOpt/libdynamicTopoFvMesh.so(_ZNK4Foam16cellSetAlgorithm8containsEi+0x25) [0x7f79129aece5]
[manjaro:04289] [ 6] /home/olivier/OpenFOAM/olivier-1.6-ext/lib/linux64Gcc46DPOpt/libdynamicTopoFvMesh.so(_ZN4Foam17dynamicTopoFvMesh21computeCoupledWeightsEiiRNS_4ListIiEERNS_5FieldIdEERNS4_INS_6VectorIdEEEEb+0x269) [0x7f7912917689]
[manjaro:04289] [ 7] /home/olivier/OpenFOAM/olivier-1.6-ext/lib/linux64Gcc46DPOpt/libdynamicTopoFvMesh.so(_ZN4Foam17dynamicTopoFvMesh14computeMappingEdbbiiii+0x405) [0x7f79128b30d5]
[manjaro:04289] [ 8] /home/olivier/OpenFOAM/olivier-1.6-ext/lib/linux64Gcc46DPOpt/libdynamicTopoFvMesh.so(_ZN4Foam17dynamicTopoFvMesh20computeMappingThreadEPv+0x126) [0x7f79128b65b6]
[manjaro:04289] [ 9] /home/olivier/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/libOpenFOAM.so(_ZN4Foam13multiThreader10poolThreadEPv+0x6e) [0x7f79215548fe]
[manjaro:04289] [10] /usr/lib/libpthread.so.0(+0x80a2) [0x7f791fbd10a2]
[manjaro:04289] [11] /usr/lib/libc.so.6(clone+0x6d) [0x7f792034a3dd]
[manjaro:04289] *** End of error message ***
Regards,
Olivier
Old   January 19, 2014, 18:31
Sandeep Menon
deepsterblue will become famous soon enough
Olivier,
I've posted a fix for the floating-point exception issue. I'm not sure what's going on with the cellCells error - does it occur only in Debug?
[EDIT:]
Also - are you running this multi-threaded (i.e., threads > 1)?
Thanks
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
Last edited by deepsterblue; January 19, 2014 at 18:36. Reason: Add info about threads
deepsterblue is offline   Reply With Quote
Old   January 20, 2014, 12:53
olivier Skurtys
Sandeep,
I tested your latest version. The error is still there.
==> no
==> yes
Regards
Old   January 20, 2014, 12:59
Sandeep Menon
Okay.. I'll look into the multi-threaded issue. Can you try with single-threaded for now, and see if the rest works?
Thanks
Sandeep Menon
Old   January 20, 2014, 14:16
Sandeep Menon
I've fixed the multi-threading issue as well. Hopefully, it should work now.
hua1015 likes this.
Sandeep Menon
Old   January 20, 2014, 22:04
olivier Skurtys
Sandeep:
Yes it works very fine, congratulation. However, now after various time steps, I have a problem at the boundaries, sorry
Min: 0.351905
Max: 1
Mean: 0.832525
Cells: 159046
[1]
[2]
[2]
[2] --> FOAM FATAL ERROR:
[2] face 30 area does not match neighbour by 0.0101978% -- possible face ordering problem.
patch: procBoundary2to1 my area:4.1039e-09 neighbour area: 4.10432e-09 matching tolerance: 0.0001
Mesh face: 76429 vertices: 3((0.0111005 0.0171076 0.0104443) (0.0110425 0.0170291 0.0105041) (0.0111254 0.0170277 0.0104461))
Rerun with processor debug flag set for more information.[1]
[1] --> FOAM FATAL ERROR:
[1] face 30 area does not match neighbour by 0.0101978% -- possible face ordering problem.
patch: procBoundary1to2 my area:4.10432e-09 neighbour area: 4.1039e-09 matching tolerance: 0.0001
Mesh face: 79637 vertices: 3((0.0111005 0.0171076 0.0104443) (0.0111254 0.0170277 0.0104461) (0.0110425 0.0170291 0.0105041))
[1]
[1] From function processorPolyPatch::calcGeometry()
[1] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 216.
[1]
FOAM parallel run exiting
[1]
[2]
[2] From function processorPolyPatch::calcGeometry()
[2] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 216.
[2]
[2]
MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 1 with PID 5264 on
node manjaro exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[manjaro:05262] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[manjaro:05262] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Tomorrow, I will run in debug mode
Regards,
Olivier
Old   January 21, 2014, 10:06
olivier Skurtys
Sandeep:
I carried out a run in debub mode:
Min: 0.351905
Max: 1
Mean: 0.832525
Cells: 159046
From function void fvMesh::movePoints(const mapPolyMesh& meshMap)
in file fvMesh/fvMesh.C at line 594
Grabbing old cell volumes.
tmp<scalarField> polyMesh::movePoints(const pointField&) : Moving points for time 0.00042 index 42
Moving object leastSquaresVectors
Moving object mesquiteMotionSolver
Done moving
[1] [2]
[1]
[1]
[2]
[2]
[2] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.Cface 30 area does not match neighbour by 0.0101978% -- possible face ordering problem.
[1]
[1] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line at line 216.
[2]
[2]
216.
[1]
Regards,
Olivier
Old   January 21, 2014, 10:56
Sandeep Menon
Could you give me a test case that I can work with?
Sandeep Menon
Old   April 28, 2014, 20:07
olivier Skurtys
Hi Sandeep,
A good day to you! I have modified the solver (it can work now in parallel and take in account viscous forces). Now, I am working with foam3.0 and I use parMetis method.
The solver works fine during various time steps, about 30000, up to an error:
ExecutionTime = 179843 s  ClockTime = 183110 s
Courant Number mean: 0.000429068 max: 0.007494 velocity magnitude: 0.346252
Time = 0.28947
 Min: 0.074796
 Max: 0.999982
 Mean: 0.849104
 Cells: 132815
 Topo modifier time: 0.687138 s
 Swaps      :: Total: 3, Surface: 2
 Mapping time: 7e-06 s
 Reordering time: 0.03978 s
[1]
[1]
[1]  Mapping for inserted boundary face is incorrect. Found an empty masterObjects list.
 Face: 46348
 Patch: particle1
[1]
[1]     From function void topoPatchMapper::calcInsertedFaceAddressing() const
[1]     in file fieldMapping/topoPatchMapper.C at line 137.
[1]
[1]
code>
When I run another test case, I have the same error but on another patch.
Have you an idea?
Regards,
Olivier
Old   April 29, 2014, 17:31
Sandeep Menon
Olivier,
If you are able to reproduce this consistently, then it would be helpful if you could write out the mesh at the time-step just prior to the crash, and then restart the simulation with a higher debug level (valid up to level 5) to produce more output. This should write out a few VTK files (related to the swaps) that you can visualize, and would also help me figure out what might be wrong.
Glad to know that you're finding this useful.
Sandeep Menon
Old   May 4, 2014, 20:32
Mibte is on a distinguished road
Hi Sandeep,
I have the same error than the one at post #91 from this page when running the GDI engine case. Bruno (wyldckat) have been helping me to resolve the issues with relation to the case, from the problem with the load balancing process and the loading of the parMetis libraries to the one with debbuging the dynamic mesh. Here are the results:
http://www.cfd-online.com/Forums/ope...balancing.html
I have sent to you through a private message the link to the debug package "turbDyMEngineFoam4subdomains.debug_at_358.3_3 58.4 .tar.gz" as well as the original case.
Thank you very much, Alvaro.
Mibte is offline   Reply With Quote
Old   September 19, 2014, 05:42
Default Tutorial for openFoam 2.3.0
  #94
Paritosh Vasava
vasava will become famous soon enough
I am using openFoam 2.3.0 and I managed to compile both the mesquite and the dynamicTopoFvMesh. I could run the text example circCylinder3d by Mooney (7th openFoam workshop) after initial hitch.
However I do not understand the other tutorials.
  1. ballTranslation: The controlDict file does not have solver name. When I try to run the case with the 'Allrun' file that came with the case, it creates an empty log file and stops.
  2. needleValveClosure: The controlDict file has line 'application icoFoamAutoMotion' which is suppose is the solver name. When I I try to run the case with the 'Allrun' file that came with the case, it creates a log file with following line.
    /opt/openfoam230/bin/tools/RunFunctions: line 52: icoFoamAutoMotion: command not found
  3. projectile: The controlDict file does not have solver name and there is no 'Allrun' file with the case.
Here is link to Kyle Mooney's files from the workshop.
Of course the tutorials were for old openFoam versions but can someone can please suggest modifications for openFoam2.3.0.
In addition I have a case where a cube with in another cube is rotating with some speed. I want the mesh to update while the cube is rotating. Of course with current setup it does not. It would be nice if someone can help me fix this case. Here is link to the case.
http://www.mediafire.com/download/mb...bject_mod3.zip
vasava is offline   Reply With Quote
Old   January 27, 2016, 10:40
Question Points between two slip boundaries do not move correctly with mesquiteMotionSolver
  #95
Lu ZHOU
lzhou is on a distinguished road
Hello ,
I would like to use Mesquite Motion Solver coupled with dynamicTopoFvMesh to simulate a case with a deforming boundary (which is deformed based on calculated data) .
I created a simple case based on the circCylinder3dHex tutorial but I got a problem. The points on the line between two slip boundaries do not move correctly as showed in pictures. I uploaded my case and please help me find out where did I make a mistake...(I am using Foam-extend 3.1)
By the way, I would like to use Mesquite Motion solver with interDyMFoam. However, the alpha1 value is not correct when the mesh is deformed. Could someone give me some suggestions about how to solve this problem ?
Thanks in advance !
Best regards !
Lu ZHOU
lzhou is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] snappyHexMesh refinement regions ignored guitarbren OpenFOAM Meshing & Mesh Conversion 2 April 9, 2013 04:59
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 10:13
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
