interFoam/kOmegaSST tank filling with printStackError/Mules
Old   December 12, 2012, 08:39
Default interFoam/kOmegaSST tank filling with printStackError/Mules
Simon Arne
simpomann is on a distinguished road
Hey there,
I am simulating the filling of a tank with interfoam and try to use k-Omega-SST model for turbulence. The mesh has around 400.000 cells, checkMesh says okay. Unluckily I encounter these errors a lot (sometimes after 0.25s, with different transport properties after 0.4s):
MULES: Solving for alpha1
Liquid phase volume fraction = 0.00200676  Min(alpha1) = -6.28037e-20  Max(alpha1) = 1
GAMG:  Solving for p_rgh, Initial residual = 0.524686, Final residual = 0.000681733, No Iterations 2
time step continuity errors : sum local = 1.32975e-10, global = 2.51813e-15, cumulative = -1.01128e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.0920533, Final residual = 7.70789e-08, No Iterations 5
time step continuity errors : sum local = 2.09622e-14, global = -1.45744e-18, cumulative = -1.01128e-05
DILUPBiCG:  Solving for omega, Initial residual = 0.000158889, Final residual = 7.80272e-08, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 0.00244614, Final residual = 5.717e-10, No Iterations 2
bounding k, min: -0.000200721 max: 3.00901e+20 average: 1.31669e+15
ExecutionTime = 24866.4 s  ClockTime = 24916 s
Courant Number mean: 2.01358e-08 max: 0.712635
Interface Courant Number mean: 8.29938e-09 max: 0.282305
deltaT = 2.2569e-14
Time = 0.2550889169617
GAMG:  Solving for p_rgh, Initial residual = 0.408204, Final residual = 0.000561119, No Iterations 2
time step continuity errors : sum local = 2.68439e-10, global = -5.36369e-15, cumulative = -1.01128e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.0698315, Final residual = 5.11837e-08, No Iterations 5
time step continuity errors : sum local = 3.27413e-14, global = -7.29092e-18, cumulative = -1.01128e-05
DILUPBiCG:  Solving for omega, Initial residual = 0.00329008, Final residual = 2.10387e-10, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.0124975, Final residual = 7.00019e-09, No Iterations 2
ExecutionTime = 24868.6 s  ClockTime = 24919 s
Courant Number mean: 3.59009e-08 max: 3.49031
Interface Courant Number mean: 1.43023e-08 max: 0.550178
deltaT = 5.17294e-15
Time = 0.255088916961705
GAMG:  Solving for p_rgh, Initial residual = 0.587722, Final residual = 0.000830391, No Iterations 2
time step continuity errors : sum local = 7.64239e-11, global = 4.21113e-16, cumulative = -1.01128e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.0960292, Final residual = 3.83386e-08, No Iterations 6
time step continuity errors : sum local = 5.13861e-15, global = -9.16091e-19, cumulative = -1.01128e-05
DILUPBiCG:  Solving for omega, Initial residual = 0.000484156, Final residual = 1.42813e-08, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 0.00071846, Final residual = 1.26128e-09, No Iterations 2
ExecutionTime = 24870.9 s  ClockTime = 24921 s
Courant Number mean: 1.32675e-08 max: 0.702258
Interface Courant Number mean: 5.5049e-09 max: 0.202586
deltaT = 5.76223e-15
Time = 0.25508891696171
Liquid phase volume fraction = 0.00200676  Min(alpha1) = -6.28036e-20  Max(alpha1) = 1
GAMG:  Solving for p_rgh, Initial residual = 0.143881, Final residual = 0.000365565, No Iterations 2
time step continuity errors : sum local = 4.46931e-11, global = -4.75218e-15, cumulative = -1.01128e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.0402696, Final residual = 3.67927e-08, No Iterations 6
time step continuity errors : sum local = 4.85566e-15, global = -1.63317e-18, cumulative = -1.01128e-05
DILUPBiCG:  Solving for omega, Initial residual = 8.34399e-05, Final residual = 9.95434e-12, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00146217, Final residual = 2.85304e-10, No Iterations 2
ExecutionTime = 24873.2 s  ClockTime = 24923 s
Courant Number mean: 1.83689e-08 max: 0.546694
Interface Courant Number mean: 7.7516e-09 max: 0.262968
deltaT = 6.60544e-15
Time = 0.255088916961717
GAMG:  Solving for p_rgh, Initial residual = 0.0613232, Final residual = 0.000199917, No Iterations 2
time step continuity errors : sum local = 3.64953e-11, global = 1.40235e-15, cumulative = -1.01128e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.00862543, Final residual = 7.72936e-08, No Iterations 5
time step continuity errors : sum local = 1.45349e-14, global = 4.97913e-17, cumulative = -1.01128e-05
DILUPBiCG:  Solving for omega, Initial residual = 0.000305148, Final residual = 9.20208e-08, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 0.00171966, Final residual = 6.46387e-10, No Iterations 2
bounding k, min: -2.15624e+09 max: 2.68344e+21 average: 1.08957e+16
ExecutionTime = 24875.4 s  ClockTime = 24925 s
Courant Number mean: 2.361e-08 max: 0.507769
Interface Courant Number mean: 1.01369e-08 max: 0.318716
deltaT = 7.64614e-15
Time = 0.255088916961725
GAMG:  Solving for p_rgh, Initial residual = 0.24767, Final residual = 0.000361503, No Iterations 2
time step continuity errors : sum local = 1.34031e-10, global = 3.46138e-15, cumulative = -1.01128e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.0585152, Final residual = 3.09369e-08, No Iterations 5
time step continuity errors : sum local = 1.38894e-14, global = 8.65978e-17, cumulative = -1.01128e-05
DILUPBiCG:  Solving for omega, Initial residual = 0.00217707, Final residual = 1.56868e-10, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00609363, Final residual = 2.66106e-09, No Iterations 2
ExecutionTime = 24877.6 s  ClockTime = 24928 s
Courant Number mean: 3.25704e-08 max: 1.92022
Interface Courant Number mean: 1.36638e-08 max: 0.455131
deltaT = 3.18553e-15
Time = 0.255088916961728
[3] #0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #2   in "/lib64/libc.so.6"
[3] #3  void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[3] #4   at MULES.C:0
[3] #5  Foam::MULES::explicitSolve(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) in "/opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[3] #6
[3]  in "/opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/interFoam"
[3] #7  __libc_start_main in "/lib64/libc.so.6"
[3] #8
[3]  at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116
[c103-06:14726] *** Process received signal ***
[c103-06:14726] Signal: Floating point exception (8)
[c103-06:14726] Signal code:  (-6)
[c103-06:14726] Failing at address: 0x35c600003986
[c103-06:14726] [ 0] /lib64/libc.so.6(+0x34e10) [0x7fd91ae43e10]
[c103-06:14726] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x7fd91ae43d95]
[c103-06:14726] [ 2] /lib64/libc.so.6(+0x34e10) [0x7fd91ae43e10]
[c103-06:14726] [ 3] /opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam5MULES7limiterINS_17geometricOneFieldENS_9zeroFieldES3_EEvRNS_5FieldIdEERKT_RKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEERKNSA_IdNS_13fvsPatchFieldENS_11surfaceMeshEEESK_RKT0_RKT1_ddi+0x1068) [0x7fd91ca71fa8]
[c103-06:14726] [ 4] /opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(+0x7c007e) [0x7fd91ca6507e]
[c103-06:14726] [ 5] /opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam5MULES13explicitSolveERNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERS8_dd+0x80) [0x7fd91ca65310]
[c103-06:14726] [ 6] interFoam() [0x42d35e]
[c103-06:14726] [ 7] /lib64/libc.so.6(__libc_start_main+0xed) [0x7fd91ae3023d]
[c103-06:14726] [ 8] interFoam() [0x425119]
[c103-06:14726] *** End of error message ***
mpirun noticed that process rank 3 with PID 14726 on node c103-06 exited on signal 8 (Floating point exception).
Timestep decreases and this happens. I checked velocities and pressure at the last working timestep, nothing out of hand here.
I guess I have to supply my fvSchemes, fvSolutions and my initial conditions to trace this. My guess is a connection to the k-Omega-SST model. Probably my initial settings are bad, but I calculated them several times following the wiki here and can't manage to get it work.
Case is currently starting laminar, if this works I will update you asap.
U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    walls
        type            fixedValue;
        value           uniform (0 0 0);
    //Durchströmt
    inlet
       type            flowRateInletVelocity;
       flowRate          constant 0.000666667;//incompressible solver: [m³/s]
       value           uniform (0 0 0); //placeholder
    //type            fixedValue;            //Alternative, Sascha
        //value           (1.36 -2.56 0);
     atmosphaere_CATIASTL
        type            zeroGradient;
    //Alles was umströmt wird
    tank_CATIASTL
        type            fixedValue;
    efr_CATIASTL
        type            fixedValue;
    entl_CATIASTL
        type            fixedValue;
    pistole_vorn_CATIASTL
        type            fixedValue;
    pistole_hinten_CATIASTL
        type            fixedValue;
    innenteile_CATIASTL
        type            fixedValue;
    flv_CATIASTL
        type            fixedValue;
   einsatz_efr_CATIASTL
        type            fixedValue;
    verschlusskopf_CATIASTL
        type            fixedValue;
p_rgh
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    walls
        type            buoyantPressure;
        value           uniform 0;
    //Durchströmt
    inlet
        value           uniform 0;
        type            totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
    tank_CATIASTL
        value           uniform 0;
    efr_CATIASTL
        value           uniform 0;
    entl_CATIASTL
        value           uniform 0;
        value           uniform 0;
   // sd_CATIASTL
    //    type            buoyantPressure;
    //    value           uniform 0;
        value           uniform 0;
    innenteile_CATIASTL
        value           uniform 0;
    flv_CATIASTL
        value           uniform 0;
        value           uniform 0;
        value           uniform 0;
k
dimensions      [ 0 2 -2 0 0 0 0 ];
internalField   uniform 0.0286;
boundaryField
    walls
        type            kqRWallFunction;
        value           $internalField;
    //Durchströmt
    inlet
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.041;       // 5% turbulent intensity
        type            inletOutlet;
        inletValue      $internalField;
    tank_CATIASTL
    efr_CATIASTL
    entl_CATIASTL
    sd_CATIASTL
    innenteile_CATIASTL
    flv_CATIASTL
Omega
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 1643.71;
boundaryField
    walls
        type            omegaWallFunction;
    //Durchströmt
    inlet
        type            fixedValue;
        value           uniform 280.78;
        type            inletOutlet;
    tank_CATIASTL
    efr_CATIASTL
    entl_CATIASTL
    sd_CATIASTL
    innenteile_CATIASTL
    flv_CATIASTL
Nut
dimensions      [ 0 2 -1 0 0 0 0 ];
internalField   uniform 0.00010198;
boundaryField
    walls
        type            nutkWallFunction;
    //Durchströmt
    inlet
        type            calculated;
        value           uniform 0.00010198;
        type            calculated;
    tank_CATIASTL
    efr_CATIASTL
    entl_CATIASTL
    sd_CATIASTL
    innenteile_CATIASTL
    flv_CATIASTL
I guess inlet is self explaining. The only outlet is "atmosphaere". All the other stuff are pipes etc, so basically walls.
If somebody spots a mistake in one of the files please tell me! I am super lost with this.
All help is highly appreciated! Big thanks and best regards!
I hope somebody with more experience can help me to fix this, unluckily it's a bit urgent for my thesis.
Greetings!
Simon
simpomann is offline   Reply With Quote
Old   December 12, 2012, 08:40
Simon Arne
fvSchemes
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;            //Alternative:default cellMDLimited Gauss linear 1
divSchemes
    div(rho*phi,U)  Gauss limitedLinearV 1;
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss interfaceCompression;
    div(phi,k)      Gauss upwind;
    div(phi,omega)  Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p;
    pcorr;
    alpha1;
    p_rgh;
fvSolutions
solvers
    p_rgh                //Lösung der Druckgleichung
        solver          GAMG;
        tolerance       1e-07;
        relTol          0.01;
        smoother        DIC;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    p_rghFinal                //finaler Loop
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance       1e-07;
            relTol          0;
            nVcycles        2;
            smoother        DICGaussSeidel;
            nPreSweeps      2;
            nPostSweeps     2;
            nFinestSweeps   2;
            mergeLevels     1;
        tolerance       1e-07;
        relTol          0;
        maxIter         10;
    pcorr                //vor dem Loop gelöste Druckvergleichung für Startwerte des Feldes innerhalb des Iterationsschritts
        solver          PCG;
        preconditioner
            tolerance       1e-05;
            relTol          0;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            cacheAgglomeration false;
            mergeLevels     1;
        tolerance       1e-05;
        relTol          0;
        maxIter         10;
    "(U|k|omega)"
        solver          smoothSolver;
        smoother        GaussSeidel;
        tolerance       1e-06;
        relTol          0.1;
        nSweeps         1;
    "(U|k|omega)Final"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-07;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    nAlphaCorr      1;
    nAlphaSubCycles 2;
    cAlpha          1;  // Alternative 0
And alpha (dont expect problems here)
dimensions      [0 0 0 0 0 0 0];
boundaryField
    walls
        type            zeroGradient;
    //Durchströmt
    inlet
        type            fixedValue;
        value           uniform 1;
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    tank_CATIASTL
        type            zeroGradient;
    efr_CATIASTL
        type            zeroGradient;
    entl_CATIASTL
        type            zeroGradient;
        type            zeroGradient;
    sd_CATIASTL
        type            zeroGradient;
        type            zeroGradient;
    innenteile_CATIASTL
        type            zeroGradient;
    flv_CATIASTL
        type            zeroGradient;
        type            zeroGradient;
        type            zeroGradient;
Old   December 12, 2012, 13:11
Simon Arne
Hey,
I checked a lamniar case. Same error but at a different timestep
Liquid phase volume fraction = 0.00157538  Min(alpha1) = -1.62932e-21  Max(alpha1) = 1
GAMG:  Solving for p_rgh, Initial residual = 0.065834, Final residual = 0.000307154, No Iterations 2
time step continuity errors : sum local = 2.85125e-12, global = -6.3837e-15, cumulative = -3.90402e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.02062, Final residual = 3.97336e-08, No Iterations 7
time step continuity errors : sum local = 3.9867e-16, global = -5.09275e-19, cumulative = -3.90402e-05
ExecutionTime = 15548.4 s  ClockTime = 15612 s
Courant Number mean: 2.84517e-08 max: 0.867998
Interface Courant Number mean: 5.5157e-09 max: 0.0944208
deltaT = 4.14157e-15
Time = 0.202400597327766
Liquid phase volume fraction = 0.00157538  Min(alpha1) = -1.62931e-21  Max(alpha1) = 1
GAMG:  Solving for p_rgh, Initial residual = 0.0662251, Final residual = 0.000298758, No Iterations 2
time step continuity errors : sum local = 2.77135e-12, global = -4.86472e-15, cumulative = -3.90402e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.0204396, Final residual = 3.2508e-08, No Iterations 7
time step continuity errors : sum local = 3.2613e-16, global = -4.25822e-19, cumulative = -3.90402e-05
ExecutionTime = 15550.6 s  ClockTime = 15614 s
Courant Number mean: 2.84501e-08 max: 0.867991
Interface Courant Number mean: 5.51484e-09 max: 0.0943805
deltaT = 3.81716e-15
Time = 0.202400597327769
GAMG:  Solving for p_rgh, Initial residual = 0.0657749, Final residual = 0.00031065, No Iterations 2
time step continuity errors : sum local = 2.88026e-12, global = -6.24636e-15, cumulative = -3.90402e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.0206025, Final residual = 3.60495e-08, No Iterations 7
time step continuity errors : sum local = 3.61229e-16, global = -3.50359e-19, cumulative = -3.90402e-05
ExecutionTime = 15552.7 s  ClockTime = 15616 s
Courant Number mean: 2.84444e-08 max: 0.867923
Interface Courant Number mean: 5.6614e-09 max: 0.094348
deltaT = 3.51843e-15
Time = 0.202400597327773
GAMG:  Solving for p_rgh, Initial residual = 0.0661369, Final residual = 0.000300055, No Iterations 2
time step continuity errors : sum local = 2.77963e-12, global = -4.82001e-15, cumulative = -3.90402e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.0204266, Final residual = 3.17341e-08, No Iterations 7
time step continuity errors : sum local = 3.17909e-16, global = -3.68428e-19, cumulative = -3.90402e-05
ExecutionTime = 15554.9 s  ClockTime = 15619 s
Courant Number mean: 2.8439e-08 max: 0.867925
Interface Courant Number mean: 5.317e-09 max: 0.094304
deltaT = 3.24307e-15
Time = 0.202400597327776
GAMG:  Solving for p_rgh, Initial residual = 0.0657622, Final residual = 0.00031015, No Iterations 2
time step continuity errors : sum local = 2.87193e-12, global = -6.3359e-15, cumulative = -3.90402e-05
GAMGPCG:  Solving for p_rgh, Initial residual = 0.0205844, Final residual = 3.79572e-08, No Iterations 7
time step continuity errors : sum local = 3.79847e-16, global = -3.64393e-19, cumulative = -3.90402e-05
ExecutionTime = 15557.1 s  ClockTime = 15621 s
Courant Number mean: 2.84311e-08 max: 0.867857
Interface Courant Number mean: 5.31414e-09 max: 0.0942674
deltaT = 2.9895e-15
Time = 0.202400597327779
[3] #4   at MULES.C:0
[3] #6
[3] #8
[c103-06:28794] *** Process received signal ***
[c103-06:28794] Signal: Floating point exception (8)
[c103-06:28794] Signal code:  (-6)
[c103-06:28794] Failing at address: 0x35c60000707a
[c103-06:28794] [ 0] /lib64/libc.so.6(+0x34e10) [0x7f3d0d63ae10]
[c103-06:28794] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x7f3d0d63ad95]
[c103-06:28794] [ 2] /lib64/libc.so.6(+0x34e10) [0x7f3d0d63ae10]
[c103-06:28794] [ 3] /opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam5MULES7limiterINS_17geometricOneFieldENS_9zeroFieldES3_EEvRNS_5FieldIdEERKT_RKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEERKNSA_IdNS_13fvsPatchFieldENS_11surfaceMeshEEESK_RKT0_RKT1_ddi+0x1068) [0x7f3d0f268fa8]
[c103-06:28794] [ 4] /opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(+0x7c007e) [0x7f3d0f25c07e]
[c103-06:28794] [ 5] /opt/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam5MULES13explicitSolveERNS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERS8_dd+0x80) [0x7f3d0f25c310]
[c103-06:28794] [ 6] interFoam() [0x42d35e]
[c103-06:28794] [ 7] /lib64/libc.so.6(__libc_start_main+0xed) [0x7f3d0d62723d]
[c103-06:28794] [ 8] interFoam() [0x425119]
[c103-06:28794] *** End of error message ***
mpirun noticed that process rank 3 with PID 28794 on node c103-06 exited on signal 8 (Floating point exception).
As far as I understand, there is an error during the alpha calculation. But what can cause it? If the turbulence model is allright, checkMesh says okay.... where can I start searching my answers?
Could it be this part from my fvSolution?
PIMPLE { momentumPredictor no; nCorrectors 2; nNonOrthogonalCorrectors 0; nAlphaCorr 1; nAlphaSubCycles 2; cAlpha 1; // Alternative 0 }
Old   February 17, 2014, 18:06
Matej Muller
matejmuller is on a distinguished road
Hey Simon!
Have you perhaps solved this issue? I'm also trying to run interFoam with the kOmega model and also don't know which solvers and schemes to use, since the tutorial of kOmegaSST exists only for the LTSInterFoam. Have you figured out the right solvers and schemes?
thanks for the help,
Matej
matejmuller is offline   Reply With Quote
Filling Tank with Water leff CFX 7 August 21, 2017 08:47
BCs to the outlet patch (filling a simple tank) Ternox OpenFOAM Pre-Processing 4 August 21, 2017 08:19
tank filling (water/air), I think I messed up the BCs simpomann OpenFOAM Running, Solving & CFD 2 August 21, 2017 08:16
free-surface liquid filling a fuel tank lee CFX 2 June 4, 2008 22:01
how to set boundary condition for a tank filling w namrata FLUENT 6 May 2, 2007 11:23
