Adding a source term to k and epsilon equation for buoyancy
Old   December 7, 2012, 10:53
Default Adding a source term to k and epsilon equation for buoyancy
Rajesh Kumar
rajeshkunwar is on a distinguished road
Hi..
I am adding a term which is a function of density gradient and gravitational acceleration (g) to k and epsilon equation of compressible k-epsilon model. while compiling my new k-epsilon model, error comes as
In file included from mykEpsilon.C:268:0:
/home/rajesh/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/readGravitationalAcceleration.H:1:5: error: ‘Info’ does not name a type
/home/rajesh/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/readGravitationalAcceleration.H:2:5: error: ‘uniformDimensionedVectorField’ does not name a type
mykEpsilon.C: In member function ‘virtual void Foam::compressible::RASModels::mykEpsilon::correct ()’:
mykEpsilon.C:297:29: error: ‘g’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/mykEpsilon.o] Error 1
rajesh@rajesh-OptiPlex-990:~/OpenFOAM/rajesh-2.1.1/src/turbulenceModels/compressible/RAS/mykEpsilon$
Pls help....
rajeshkunwar is offline   Reply With Quote
Old   May 15, 2014, 14:41
Srivathsan N
Sherlock_1812 is on a distinguished road
It seems that there is some error in your readgravitationalacceleration.H file. The second error in your .C file also points to not being able to read properly. Make sure that the contents of the above mentioned .H file are correct.
I am also working on buoyancy driven flows. May I know how you are adding the source term for buoyancy to the k-equation?
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   April 19, 2019, 08:41
Jianrui Zeng
calf.Z is on a distinguished road
I am also wondering how I can add buoyancy term into K and epsilon.
I found Gcoef in buoyantKEpsilon and I am trying to use it.
calf.Z is offline   Reply With Quote
What's the source term in this turbulent momentum equation? lyes43 Main CFD Forum 2 December 1, 2012 12:19
Source Term on Scalar Transport Equation - crashing simulation alessio.nz OpenFOAM 19 February 8, 2011 08:38
The effect of E term in the EPSILON equation Valdemir G. Ferreira Main CFD Forum 6 June 7, 2000 03:37
Extra term in Epsilon equation Valdemir G. Ferreira Main CFD Forum 0 April 30, 2000 09:57
bouyancy term in epsilon equation Michael Main CFD Forum 1 June 25, 1999 11:20
