error in defining thermophysical properties
Old   December 6, 2012, 14:20
Default error in defining thermophysical properties
immortality's Avatar
Ehsan
immortality is on a distinguished road
I have defined the air coefficients as below;whats the reason of the error?
mixture
specie
nMoles 1;
molWeight 28.9;
thermodynamics
Tlow 200;
Thigh 6000;
Tcommon 1000;
lowCpCoeffs(5.009155110 -5.761013730E-3 1.066859930E-5 -7.940297970E-9 2.185231910E-12 -1.767967310E+02 -3.921500990E+00);
highCpCoeffs(5.144558670E+00 -2.138541790E-04 7.065227840E-08 -1.071483490E-11 6.577800150E-16 6.462263190E+03 -8.147408670E+00);
transport
As 1.4584E-06;
Ts 110.4;
PIMPLE: Operating solver in PISO mode
Reading thermophysical properties
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'lowCpCoeffs(5.009155110' on line 32 and ending at line 45"
file: /home/ehsan/Desktop/thesis_Pimple/constant/thermophysicalProperties at line 45.
From function primitiveEntry::readEntry(const dictionary&, Istream&)
in file lnInclude/IOerror.C at line 132.
FOAM exiting
immortality is offline   Reply With Quote
Old   December 6, 2012, 14:26
Ehsan
i also wrote the header as this:
thermoType hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>>;
what should I do then?
Old   December 6, 2012, 20:58
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
There is no space between your lowCp/highCp coeffs keyword and value.
mturcios777 is offline   Reply With Quote
Old   December 7, 2012, 05:37
Ehsan
thanks.you right.it was solved.do you know about thermotype?whats psi in this model?how can i change it to hRhoThermo return to hPsiThermo?
Thanks.
Old   December 7, 2012, 13:04
Marco A. Turcios
Read the OpenFOAM manual, the section on thermophysical models (7.1)
Old   December 7, 2012, 13:33
Ehsan
I have read it but it gives error after changing
Old   December 7, 2012, 13:42
Marco A. Turcios
Which thermo model do you want to use? Some of the thermos are not compatible with certain mixture or transport models. If the error happens in the initial set up of the case before the main solver loop, then you haven't specified the thermo model properly.
If the error happens in the main solver loop, then there is something wrong with your setup (inappropriate choice of thermo model, boundary conditions, etc.). This will take longer to figure out.
Please post the error to make diagnosing the error easier.
Old   December 7, 2012, 14:21
Ehsan
thank you.look at this error.I changed BC's to fixedValues but the error is repeated:
Create time
Create mesh for time = 0
Selecting thermodynamics package ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>>
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::ePsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::janafThermo<Fo am:erfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::ePsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::janafThermo<Fo am:erfectGas> > > > >::ePsiThermo(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#5 Foam::basicPsiThermo::addfvMeshConstructorToTable< Foam::ePsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::janafThermo<Fo am:erfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoCentralFoam"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception
thermophysical properties immortality OpenFOAM Running, Solving & CFD 0 December 2, 2012 07:49
chtMultiRegionFoam, error while when defining the thermodynamic properties nakor OpenFOAM Running, Solving & CFD 0 September 12, 2012 16:22
Thermophysical models and properties Gitesh P OpenFOAM Running, Solving & CFD 3 March 9, 2012 10:36
defining volume properties via UDF Ralf Schmidt FLUENT 0 July 17, 2006 11:30
thermophysical properties of ham Alex Ivancic Main CFD Forum 1 November 5, 1998 12:09
