bubblefoam totally failed on unstructured mesh. |
December 26, 2012, 11:04 |
#21 |
Dongyue Li
Rep Power: 18 |
Because I want to simulate the velocity field in a stirred tank which has two or more complex impeller and other things. the liquid is xanthan gum. and the air was injected. ofcourse I want to use hex mesh. but its too hard the create it. the image has been attached. Wish someday I can fly to IOWA..haha I will try to make a fine tet mesh and update later,now its very late in my country~but if you are interested in my research just ask me I will give you a detailed reply~ |
December 26, 2012, 11:07 |
#22 |
Alberto Passalacqua
Rep Power: 36 |
For your type of flow you will need to consider non-Newtonian flow models too, which are not available in twoPhaseEulerFoam.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
December 26, 2012, 11:11 |
#23 |
Dongyue Li
Rep Power: 18 |
January 2, 2013, 21:06 |
#24 | |
Dongyue Li
Rep Power: 18 |
I think I should post it here, sorry.
More details see here,http://www.cfd-online.com/Forums/ope...tml#post399837 Quote:
Courant Number mean: 0.0039261 max: 0.319883 Max Ur Courant Number = 0.397983 deltaT = 0.002 Time = 0.008 MULES: Solving for alpha1 MULES: Solving for alpha1 Dispersed phase volume fraction = 8.32216e-05 Min(alpha1) = -3.02366e-18 Max(alpha1) = 1 GAMG: Solving for p, Initial residual = 0.0171367, Final residual = 0.000609333, No Iterations 1 time step continuity errors : sum local = 2.04118e-05, global = -1.65081e-05, cumulative = -2.06546e-05 GAMG: Solving for p, Initial residual = 0.00123443, Final residual = 8.21305e-09, No Iterations 12 time step continuity errors : sum local = 2.75416e-10, global = -5.95165e-11, cumulative = -2.06547e-05 ExecutionTime = 20.71 s ClockTime = 21 s Courant Number mean: 0.00430036 max: 0.423144 Max Ur Courant Number = 0.452263 deltaT = 0.002 Time = 0.01 MULES: Solving for alpha1 MULES: Solving for alpha1 Dispersed phase volume fraction = 0.000108438 Min(alpha1) = -4.18974e-18 Max(alpha1) = 1 GAMG: Solving for p, Initial residual = 0.0240778, Final residual = 0.000665494, No Iterations 1 time step continuity errors : sum local = 2.28141e-05, global = -1.13576e-05, cumulative = -3.20123e-05 GAMG: Solving for p, Initial residual = 0.00362172, Final residual = 8.3694e-09, No Iterations 12 time step continuity errors : sum local = 2.8619e-10, global = -5.54905e-11, cumulative = -3.20123e-05 ExecutionTime = 31.58 s ClockTime = 31 s Courant Number mean: 0.00473514 max: 0.539752 Max Ur Courant Number = 0.623292 deltaT = 0.00142857 Time = 0.0114286 MULES: Solving for alpha1 MULES: Solving for alpha1 Dispersed phase volume fraction = 0.000129096 Min(alpha1) = -9.55797e-13 Max(alpha1) = 1 GAMG: Solving for p, Initial residual = 0.036045, Final residual = 0.00127238, No Iterations 1 time step continuity errors : sum local = 2.27111e-05, global = -1.7439e-05, cumulative = -4.94513e-05 GAMG: Solving for p, Initial residual = 0.002945, Final residual = 5.42404e-09, No Iterations 13 time step continuity errors : sum local = 9.72319e-11, global = -2.11643e-11, cumulative = -4.94513e-05 ExecutionTime = 36.55 s ClockTime = 36 s Courant Number mean: 0.000966892 max: 0.412464 Max Ur Courant Number = 0.469807 deltaT = 0.000136854 Time = 0.029042 MULES: Solving for alpha1 MULES: Solving for alpha1 Dispersed phase volume fraction = 0.3376 Min(alpha1) = -7.3195e-15 Max(alpha1) = 1.00001 GAMG: Solving for p, Initial residual = 9.81394e-06, Final residual = 7.26256e-07, No Iterations 1 time step continuity errors : sum local = 3.91702e-08, global = 7.41876e-11, cumulative = -2.8009e-06 GAMG: Solving for p, Initial residual = 3.71368e-06, Final residual = 8.62789e-09, No Iterations 7 time step continuity errors : sum local = 4.65332e-10, global = -5.75839e-12, cumulative = -2.80091e-06 ExecutionTime = 284.29 s ClockTime = 285 s Courant Number mean: 0.00247628 max: 0.490122 Max Ur Courant Number = 0.13124 deltaT = 9.56469e-05 Time = 0.0675132 MULES: Solving for alpha1 MULES: Solving for alpha1 Dispersed phase volume fraction = 0.3376 Min(alpha1) = -2.83721e-15 Max(alpha1) = 1 GAMG: Solving for p, Initial residual = 3.71895e-06, Final residual = 1.61786e-07, No Iterations 2 time step continuity errors : sum local = 4.21222e-09, global = -5.40208e-12, cumulative = -2.80081e-06 GAMG: Solving for p, Initial residual = 2.05989e-06, Final residual = 6.36106e-09, No Iterations 6 time step continuity errors : sum local = 1.65604e-10, global = 6.10213e-13, cumulative = -2.80081e-06 ExecutionTime = 1619.52 s ClockTime = 1622 s |
January 9, 2013, 04:22 |
#25 |
Dongyue Li
Rep Power: 18 |
Um....looks like this problem still exists.
March 15, 2013, 03:24 |
#26 |
Dongyue Li
Rep Power: 18 |
Its been a long while.
But until in FOAM 2.2.0, twoPhaseEulerFoam and bubbleFoam still cannot solve tet mesh. |
May 1, 2013, 02:43 |
#27 |
Dongyue Li
Rep Power: 18 |
Hi guys,
A little success.Regards to twoPhaseEulerFoam. I spent several days learning snappyhexmesh, and this solver can deal with this mesh. Last edited by sharonyue; May 1, 2013 at 03:25. |
August 14, 2016, 11:02 |
#28 | |
DANG
Rep Power: 10 |
Hi, sharonyue! I am also facing the same problem with this thread, I also tried to use snappyHexMesh to generate a more or less okay mesh for a stirred tank, but it turned out there were always prism elements. So, I am wondering did you manage to get rid of prisms in your case? If so, how did you make it? Many thanks! Regards, |
August 14, 2016, 22:08 |
#29 | |
Alberto Passalacqua
Rep Power: 36 |
I would suggest you use OpenFOAM 4.x (Foundation), and take a look at reactingTwoPhaseEulerFoam, which has been much more robust in my experience. Successfully using tet meshes is a question of choosing the appropriate schemes, so it would be useful to see what you are using in fvSchemes / fvSolution. If they come from the tutorials, it may not be ideal. I hope this helps.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. Last edited by alberto; August 14, 2016 at 22:09. Reason: typo |
August 15, 2016, 18:54 |
#30 | |
DANG
Rep Power: 10 |
Very happy to have your help here. You just helped me a lot in learning OpenQBMM a while ago, I am Dang..... As you know, I need to develop a two-phase flow solver based on OpenQBMM, Now I am struggling on that... I solved the above problem by creating pure Hex mesh for Rushton turbine using blockMesh. and also changed some settings in fvSchemes/fvSolution after searching around in this platform. But I still have two difficulties: 1. I will mainly use multiple pitch blade turbines, which are far more difficult to generate Hex mesh by blockMesh. I noticed your group have done wonderful job on this recently by using Pointwise (9th International Conference on Multiphase Flow). In a presentation by Xiaofei Hu, your mesh is so impressive, could you please shed some lights as regard to how to add/mesh zero-thickness blades/walls in pointwise? 2. I also tested multiphaseEulerFoam in a gas-liquid stirred tank, but failed to inject gas from a sparger by using the attached "fvOptions" file. This file is okay for twoPhaseEulerFoam. Do you have some suggestions on this? By the way, I used both FOAM.3.0.1 and 2.4. Many thanks in advance! Best regards, |
August 15, 2016, 23:49 |
#31 | ||||
Alberto Passalacqua
Rep Power: 36 |
I am working on a similar problem (bubble columns) with a student of mine, but the code isn't public yet. Quote:
We have worked on very large-scale industrial reactors, with complex stirrers, which were too tedious to be meshed in a CAD-like environment. We obtained excellent results, comparable to those in Pointwise, with snappyHexMesh, once we figured the settings out, and properly defined the STL (if you use SolidWorks, feel free to maximize the export quality). Quote:
Regards,
August 18, 2016, 11:32 |
#32 | |
DANG
Rep Power: 10 |
Hi Alberto, Thanks for your kind reply. I have tried hard to get rid of prisms by using snappyHexMesh, but still be bothered by them. Do you have some suggestions on this? According to your experiences, which parameters in snappyHexMeshare are crucial to your success? Is it possible because of you use a large scale tank? While I work on a lab-scale tank with ~ 0.3 m in diameter (I used Salome to generate STL file). BTW, I played with twoPhaseEulerFoam these days, but have no clear idea about "maxFullyDispersedAlpha" and "maxPartlyDispersedAlpha" under "blending" in "phaseProperties". Could you explained them? Thanks! Best, |
August 19, 2016, 22:37 |
#33 | |||
Alberto Passalacqua
Rep Power: 36 |
This allows to specify different refinement levels. We also use the implicit feature detection, which seems to better conform the mesh to the surface in all of our cases. I would recommend you create a fine-enough blockMesh box, to start from a decent mesh resolution, rather than a very coarse one. Quote:
August 21, 2016, 09:54 |
#34 | |
DANG
Rep Power: 10 |
Thanks very much for your kind reply. The information is helpful! Best regards, |
August 23, 2016, 18:17 |
#35 | |
DANG
Rep Power: 10 |
[/QUOTE]
Hi, Alberto, I think it's better to open a new thread to disccuss the reactingMultiphaseEulerFoam issues. So, I opened a new thread at the following link: http://www.cfd-online.com/Forums/ope...tml#post615294 Hope you could take a look. Best regards, Last edited by doubledang; August 24, 2016 at 05:12. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Unstructured Mesh ICEM on a cube | jerome_ | ANSYS | 0 | May 30, 2012 05:34 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
