Argon jet into Air : which solver should I use ?
Old   December 3, 2012, 10:15
Default Argon jet into Air : which solver should I use ?
eddadagow is on a distinguished road
I'm trying to solve for a (laminar) jet of (pure) Argon in ambiant air. I want to study the mixing between the gases.
However, I'm not sure of the solver I should use for that : I've been using reactingFoam, but I'm not sure that it takes into account the difference of density/compressibility effects/...
Which solver would you advise me to use in order to do that ?
eddadagow is offline   Reply With Quote
Old   December 4, 2012, 05:10
Robert
vainilreb is on a distinguished road
I'm currently using sprayFoam for a similar case, with injection, radiation, combustion and reactions off. So far my results look quite reasonable. Although sprayFoam seems to be quite consuming in terms of calculation time I think it's worth a try.
Maybe you could compare it to reactingFoam and let me know about the results? I'm unfortunately lacking the time and computation power to do so, but I assume that sprayFoam with all the options turned off is almost the same as reactingFoam.
vainilreb is offline   Reply With Quote
gas, jet, mixing, reactingfoam
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Simulation of air flow in a chamber Issa CFX 3 November 23, 2009 18:16
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
air jet simulation Yue zou Main CFD Forum 0 September 28, 1998 09:30
