starting compressible flow from incompressible flow results
Old   November 30, 2012, 14:14
Default starting compressible flow from incompressible flow results
Mihai Pruna
mihaipruna is on a distinguished road
Since my compressible solution always blows up (internal flow, subsonic, rhoSimplecFoam), and I am able to get some results running an incompressible solver (simpleFoam) , is there a way to start your solution for the compressible solver based on the pressure and velocity obtained after a certain number of iterations with the incompressible solver?
mihaipruna is offline   Reply With Quote
Old   November 30, 2012, 17:56
Lieven
Lieven will become famous soon enough
If the mesh and boundary conditions are exactly the same, you can simply copy the U and p from he simpleFoam simulation to the 0-folder of the compressible case.
If the mesh is not the same, you can have a look at mapFields (http://www.openfoam.org/docs/user/mapFields.php ).
Regards,
L
Lieven is offline   Reply With Quote
Old   December 3, 2012, 11:02
Mihai Pruna
hi Lieven
Thanks for the response. For the incompressible solver, the pressure is normalized by rho. For the incompressible solver, you set the pressure in its real units.
Any way to get around this when reusing that field?
Compressible de Laval Nozzle Flow rw511 CFX 3 May 22, 2011 20:48
Incompressible, Unsteady Cylinder Flow startingcfd Main CFD Forum 1 March 15, 2011 02:12
Natural Convection using Compressible Flow (chtMultiRegionFOAM) msarkar OpenFOAM 2 September 7, 2010 01:13
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
momentum under-relaxation for compressible flow with SIMPLE Mihai ARGHIR Main CFD Forum 0 April 7, 2000 05:58
