July 3, 2013, 12:51 |
#21 |
Rep Power: 13 |
If I make a mistake in the name of a faceZone, I have this message:
--> FOAM FATAL ERROR: Master face zone named layerPoss cannot be found. From function void Foam::layerAdditionRemoval::checkDefinition() in file layerAdditionRemoval/layerAdditionRemoval.C at line 64. FOAM aborting |
July 3, 2013, 13:19 |
#22 |
Marco A. Turcios
Rep Power: 28 |
Hmm, interesting. I didn't know rawTopoChangerFvMesh created the required. Though I wonder if updateMesh is being called correctly since the constructor isn't explicit. Can you run the properly formatted case with the global debug flag for layerAdditionRemoval and post the log? Thanks.
April 9, 2019, 09:32 |
#23 | |
Huang, Chiung Shu
Rep Power: 8 |
Can you demostrate a simple case that using the utility of rawTopochangerFvmesh calss?? Thanks a lot! regards, James. |
obstacle in a linear channel | Stephy | OpenFOAM Running, Solving & CFD | 5 | November 2, 2011 11:42 |
open channel flow with obstacle !!! | opard | OpenFOAM | 4 | May 13, 2011 07:30 |
Moving cell in a channel | yongshenglian | OpenFOAM Running, Solving & CFD | 0 | October 6, 2008 17:45 |
Translation and rotation for a moving wall | Stéphane Champmartin | FLUENT | 1 | November 28, 2006 11:57 |
Channel with 2D surface mounted obstacle | Francesco Marra | Main CFD Forum | 1 | January 5, 2000 04:49 |
