interFoam
Old   November 16, 2012, 10:44
Question interFoam
lorraineshe is on a distinguished road
i have done a simulation with interFoam. I got the error message like below:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : interFoam
Date   : Nov 16 2012
Time   : 12:11:54
Host   : "manli-VirtualBox"
PID    : 8674
Case   : /home/manli/Blasendynamik
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Calculating field g.h
time step continuity errors : sum local = 1.06596e+287, global = -6.315e+270, cumulative = -6.315e+270
GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 2.97882e-05, No Iterations 4
time step continuity errors : sum local = 3.1753e+282, global = -1.15191e+281, cumulative = -1.15191e+281
Courant Number mean: 2.76663e+287 max: 7.56694e+288
Starting time loop
Courant Number mean: 0.00365621 max: 0.1
Interface Courant Number mean: 0 max: 0
deltaT = 6.6077e-292
Time = 6.6077e-292
MULES: Solving for alpha1
Phase-1 volume fraction = 0.991857  Min(alpha1) = 0  Max(alpha1) = 1
Phase-1 volume fraction = 0.991857  Min(alpha1) = 0.00111111  Max(alpha1) = 1
Phase-1 volume fraction = 0.991857  Min(alpha1) = 0.00323727  Max(alpha1) = 1
......Reading field U
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3  void Foam::mag<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4  Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::mag<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5  Foam::interfaceProperties::calculateK() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libinterfaceProperties.so"
#6  Foam::interfaceProperties::interfaceProperties(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::IOdictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libinterfaceProperties.so"
 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/interFoam"
#8  __libc_start_main in "/lib/libc.so.6"
Floating point exception
could someone tell me, how can I solve this problem?
lorraineshe is offline   Reply With Quote
Old   November 16, 2012, 11:05
treima is on a distinguished road
you have a Courant number of 0 and a timestep of approximatly 0, perhaps this is the problem.
Can you change this? For example a maximal Courant number of 0.1?
regards
treima
treima is offline   Reply With Quote
Old   November 16, 2012, 15:51
Lieven
Lieven will become famous soon enough
It seems to me that at there is already something seriously wrong immediately after initialization
The extremely small time step (and related courant number) are, as I see it, a direct consequence of this. So I would recommend you to check boundary conditions and initial conditions of all variables (maybe the interfoam tutorial can help you).
Regards,
L
Lieven is offline   Reply With Quote
Old   November 20, 2012, 13:27
Default Bubble rising, interFoam
I have made the case simpler and checked the BC. I have made just:
all the variables zeroGradient at all sides except noslip for velocity at the inlet and fixvalue 0 for the pressure at the outlet. However, my case still doesn't work.
I wonder if it is because of the setFieldsDict, where I have used sphereToCell... to define the area of the air bubble.
who knows why...
Old   November 20, 2012, 13:41
regards
treima
Hallo treima,
I have put deltaT 0.005, deltaX 1e-4, and the velocity of the bubble 0.02m/s, therefore the Co is 1.
The mesh is like below:
The Mesh is like below:
Old   November 20, 2012, 14:19
Michiel
michielm is on a distinguished road
No!! this is only the case if you assume that you have no spurious velocities and with interFoam I am fairly certain that you do have those. The fact that the bubble velocity is 0.02 m/s does not mean that the maximum velocity in your domain is 0.02 m/s as well.
Use
adjustTimeStep yes;
in your controlDict to make sure that you get a maximum Co of the value you specify as
maxCo 0.1
in the controlDict.
By the way: if you have all zeroGradient boundaries the location of your bubble in your mesh is most likely the problem. Because then you have a zeroGradient U and a zeroGradient P at the boundary where the bubble is sticking through. This is only possible if both U and P are constant so with P constant this means that U=0 which means that the bubble cannot move over there. However, it wants to move in the rest of the domain due to buoyancy. I suggest you start of the bubble in the middle of your domain instead of halfway sticking through a boundary and see if that fixes the issue
michielm is offline   Reply With Quote
interfoam bubble
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 07:36
BoF-Group: interFoam - documentation and usage unnikrsn OpenFOAM Running, Solving & CFD 0 November 12, 2011 23:39
Segmentation fault in interFoam run through openMPI voingiappone OpenFOAM 16 November 2, 2011 07:49
Slow interFoam compared with other CFD tools? Ralph M OpenFOAM Programming & Development 1 November 17, 2010 07:46
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 22:58
