Modelled Part of Reynoldstresses in Channelflow
Old   November 16, 2012, 10:01
Default Modelled Part of Reynoldstresses in Channelflow
Marwan Sabih
LeFrog is on a distinguished road
Dear Openfoamers,
at the moment i'm running a channelflow case with a very fine constant resolution of y+=1 ortoghonal to the wall and rough resoluton in stream and spanwidth direction of (around x+= 50 and z+= 20).
For this case the modelled part of the equation become very small, what for me seems not to be really astonishing, since the y direction should have the most influence on the modeled part, but my prof says it should be the other way arround and x and z should have the most influence and hence i should a really high modelled part. For example if i'm running a dynamic Smagorinsky modell with plane avaraging in OpenFoam, what would you say has the greatest influence on the modelled SGS part - the y-direction, the x-direction or the z-direction? Would you say with (very) small celllength in y-direction and large in every other direction the modelled Part should become large?
Kind regards
Le Frog
LeFrog is offline   Reply With Quote
[ANSYS Meshing] Match Control on multi-body part tdbbz ANSYS Meshing & Geometry 2 September 19, 2012 20:43
Integer part in StarCD macro crevoise Siemens 2 July 2, 2012 04:06
[ICEM] create Part wangy1767 ANSYS Meshing & Geometry 10 June 30, 2012 19:46
[ANSYS Meshing] Identical meshes in symmetric bodies in multibody part. aarvay ANSYS Meshing & Geometry 2 May 11, 2012 12:15
[ICEM] How to mesh part by part? rikio ANSYS Meshing & Geometry 6 February 24, 2010 20:19
