non uniform nu model
Old   November 7, 2012, 12:19
Default non uniform nu model
Simone
batta31 is on a distinguished road
Hi guys, I've got a question:
I would like to set up a simulation with a "laminar" turbulence model, but with non uniform values of nu over the domain. Is that possible in openFoam?
Thanks
Simone
batta31 is offline   Reply With Quote
Old   November 8, 2012, 10:52
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Do you mean that you want a non-uniform Newtonian viscosity field?
kmooney is offline   Reply With Quote
Old   November 8, 2012, 11:53
Simone
Yes, actually I want to use the distribution of nut of a different simulation and apply it to my new case, which has to run as a laminar case but with non uniform viscosity.
Old   November 8, 2012, 12:18
kmooney's Avatar
Kyle Mooney
If you can create a volScalarField out of your old nut distrubution perhaps like this:
volScalarField myNuField = nut;
You should be able to drop it into the diffusion term in most any solver as such:
        fvVectorMatrix UEqn
            fvm::ddt(U)
          + fvm::div(phi, U)
          - fvm::laplacian(myNuField, U)
Cheers!
Old   November 8, 2012, 12:30
Simone
That's a very clever idea! Thank you very much kmooney, I'll try as soon as I can. If it doesn't work I'll come back.
Cheers!
Old   January 31, 2013, 10:27
Simone
Hi again,
I come back to this thread because I've a doubt..
Since I have a non-uniform field of viscosity, besides the term suggested,
shouldn't I insert even a term like:
(fvc::grad(U) & fvc::grad(myNuField)
To better understand my reasoning, think you have to derive the NS equation but with non-uniform spatial viscosity..if you then explode the viscous term,
div(nu*grad(U))
you should obtain both the terms above, right?
Cheers
Simone
buoyantSimpleFoam for HVAC application Mojtaba.a OpenFOAM Running, Solving & CFD 7 November 16, 2017 16:49
LES supersonic free jet martyn88 OpenFOAM 22 April 17, 2015 07:00
How to set uniform heating boundary condition? Sargam05 OpenFOAM 0 September 11, 2012 11:09
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 18:18
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
