#0 Foam::error::printStack (MotorBike tutorial)
Old   November 4, 2012, 05:48
Question #0 Foam::error::printStack (MotorBike tutorial)
GPan1 is on a distinguished road
I'm new to using OpenFoam, and I'm trying to run the motorBike tutorial case (simpleFoam) however after running potentialFoam and then running the simpleFoam solver it cuts the simulation down to 30 time steps when I should have 1000.
After ignoring the gnuplot error and opening up ParaView I can only go to frame 1, again this should be 1000 as I set it in the controlDict file.
Looking in the log file this is the series of errors I recieve:
Time = 33
smoothSolver: Solving for Ux, Initial residual = 0.546728598, Final residual = 0.02488218515, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 0.5578872898, Final residual = 0.02638530124, No Iterations 3
smoothSolver: Solving for Uz, Initial residual = 0.529061387, Final residual = 0.01646981609, No Iterations 3
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/simpleFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Any help in solving this problem would be greatly appreciated.
Regards
GPan1 is offline   Reply With Quote
motorbike, openfoam, simplefoam
[snappyHexMesh] Trying to understand the motorBike tutorial Andyjoe OpenFOAM Meshing & Mesh Conversion 10 August 10, 2014 17:57
Exchanging the geomtry in the LES motorBike tutorial simpomann OpenFOAM 1 May 26, 2012 09:26
Wrong file in motorBike tutorial? lovecraft22 OpenFOAM 3 August 4, 2011 14:03
Basic question on motorBike tutorial newToOpenFoam OpenFOAM Running, Solving & CFD 2 July 14, 2011 10:50
motorBike tutorial and Scaling - New geometry used, scaled and now large velocity!!! scott OpenFOAM 1 July 29, 2010 05:09
