Brock Lee
Rep Power: 13 ![]() |
I've seen the following post related to this...
http://www.cfd-online.com/Forums/ope...erties-ii.html ... but I was wondering if polynomialTransport & hPolynomialThermo have been implemented since so that they can used together with the ideal gas law for density? Or am I stuck trying to modify solvers and such as in the above post? If someone has an example where they successfully implemented polynomialTransport & hPolynomialThermo with the ideal gas law for density and wouldn't mind sharing, it would be much appreciated. Thanks! |
#2 | |
Martin Novák
Did you succeeded in using of the polynomialTransport together with hPolynomiaThermo? I am facing the same issue. I have requested this combination on openfoam.org and the result was that I must do it by my own. I am quite new to Openfoam, therefore I ask for any help. Best Regards Martin |
Brock Lee
Martin,
No, I did not have success in solving this issue. I just installed OF 2.2.1 though and haven't specifically looked to see if this was added yet. I'll let you know if I find anything. Brock |
#4 | |
Martin Novák
BR Martin |
#5 | |
Brock Lee
This is good news! Could you please give a more detailed explanation of the steps you took to accomplish this? Or point me to where you found instructions? Also, what OpenFOAM version are you currently using? I look forward to hearing from you! Brock |
#6 | |
Martin Novák
Best regards Martin |
hpolynomialthermo, polynomialtransport, thermophysicalproperties |
hPolynomialThermo and janafThermo in Interfoam | karthik1414 | OpenFOAM | 4 | November 24, 2011 11:23 |
polynomial thermophysical properties | jason.ryon | OpenFOAM | 2 | May 11, 2011 06:16 |
Validation of polynomialTransport and -Thermo | Hengel | OpenFOAM | 0 | November 25, 2010 12:25 |
polynomialTransport in buoyantBoussinesqsimpleFoam | David_010 | OpenFOAM | 0 | March 12, 2010 06:11 |
janafThermo: How to read formula? or at least: How to use hPolynomialThermo? | bgoeppner | OpenFOAM | 0 | February 22, 2010 15:17 |
