unsteady ramp inlet condition
Old   October 16, 2012, 07:12
Default unsteady ramp inlet condition
pepe.aero is on a distinguished road
Hi all,
i'm trying to assign unsteady inlet boundary condition (ramp-shaped UX profile) working on a multiphase problem.
In OF 2.1.1 I can do it using the uniformFixedValue type by this way in the 0/U file:
inlet
type uniformFixedValue;
uniformValue csvFile;
csvFileCoeffs
fileName "$FOAM_CASE/u_ramp.txt"
outOfBounds clamp;
hasHeaderLine true;
refColumn 0;
componentColumns (1 2 3);
where the u_ramp.txt is something like the following:
Time,Ux,Uy,Uz
0.00, 0.0, 0.0, 0.0
0.01, 0.0, 0.0, 0.0
0.02, -0.066363, 0.0, 0.0
0.03, -0.132726, 0.0, 0.0
0.04, -0.199089, 0.0, 0.0
0.05, -0.265452, 0.0, 0.0
0.06, -0.331815, 0.0, 0.0
0.07, -0.398178, 0.0, 0.0
0.08, -0.464541, 0.0, 0.0
0.09, -0.530904, 0.0, 0.0
0.10, -0.597267, 0.0, 0.0
0.11, -0.663630, 0.0, 0.0
0.12, -0.730000, 0.0, 0.0
0.13, -0.730000, 0.0, 0.0
0.14, -0.730000, 0.0, 0.0
0.15, -0.730000, 0.0, 0.0
The problem is: Paraview reports this error trying to visualize results:
ERROR: In /home/utkarsh/Kitware/superbuild/paraview/src/paraview/VTK/IO/vtkOpenFOAMReader.cxx, line 6535
vtkOpenFOAMReaderPrivate (0x298a3d0): Wrong list type for uniform field
Is not all. In the variable list available to be visualized I can't find U for inlet boundary, and I find U (of cell) just for internalMesh, while the interpolated one does not appear.
In my idea this is not a post-processing problem, but my doubt is if I setup the unsteady boundary condition properly.
Has anyone experiences with a ramp inlet in OpenFOAM?
Thanks for your support,
Kind regards,
Andrea
pepe.aero is offline   Reply With Quote
Old   October 16, 2012, 09:08
Michiel
michielm is on a distinguished road
I have noticed that ParaView doesn't always understand the uniformFixedValue boundary condition if I load the files from vtk of with a .foam file.
However, if I use paraFoam it works well, because apparently there is some conversion that fixes the problem. Have you used paraFoam to open your dataset?!
michielm is offline   Reply With Quote
Old   October 16, 2012, 10:23
Hi Michiel,
thanks a lot for your reply. I was used to use the paraview command instead of paraFoam. You're right, using paraFoam the problem is fixed. Good.
A second issue is: OpenFOAM shows me some convergence problems using the unsteady boundary condition. I'm using a ramp at inlet to grow up gradually the velocity in order to assign a smooth velocity profile and reach convergence in less iterations.
But the result at the moment is that I reach no convergence by this way. So, do I have to change something in the numerical parameters (fvSchemes, fvSolutions) in order to suit unsteady BCs?
Thanks again for your help!
Regards,
Andrea
Old   October 16, 2012, 11:42
Michiel
Hi Andrea,
To be able to answer that I need to know more about the case you are trying to model.
What are you modelling and what are the boundary conditions you are applying?!
Old   October 16, 2012, 16:45
sure I give you all details.
I'm working on naval application of a hull in a multiphase flow. The problem can be referred to the wigley-hull tutorial, but I'm trying to improve different features, such as an unsteady ramp inlet boundary condition.
The hull is in a 3D rectangular domain and I've attached files regarding numerical parameters and all boundary conditions.
Notice that the initial position of free surface (alpha1 is mass fraction) is set with command setFields just before the start of the computation.
I really appreciate your support!
Kind regards,
Andrea
Old   October 18, 2012, 06:05
Michiel
Hi Andrea,
I can't really find a clear reason for the case not to converge.
Do you have convergences issues in the inner or the outer loop of your iterations?
Old   August 7, 2013, 04:33
Stefan Hildenbrand
shildenbrand is on a distinguished road
Hi all,
I have the same problem as in post #1 in this thread.
My configuration: OF 2.2.1 and Paraview 4.0.1
Since I could not compile the PV3 readers for ParaView 4 I use the PV builtin-reader - which works well, except for the case with a Boundary condition "uniformFixedValue".
That's why using paraFoam makes no difference in my case.
Any ideas how to fix this problem?
Stefan
shildenbrand is offline   Reply With Quote
Old   August 25, 2013, 12:43
Stephen Bosch
pajot is on a distinguished road
Hi Stefan:
Originally Posted by shildenbrand View Post
Hi all,
Stefan
Unfortunately, I come not with a solution but to report that I have the same issue, and I'm running OF 2.2.1 and Paraview 3.98.0. It makes no difference that I am running paraFoam (if I just paraview, it can't read the OF results anyway).
Are you running a multiprocessor simulation?
pajot is offline   Reply With Quote
Old   August 26, 2013, 06:03
Stefan Hildenbrand
Hi Stephen,
yes I run a multiprocessor simulation, but the error is coming up no matter if I read in the decomposed or the reconstructed case.
Old   October 22, 2013, 01:57
Jakob Hærvig
hrvig is on a distinguished road
Did you manage to solve this?
hrvig is offline   Reply With Quote
Old   October 22, 2013, 05:23
Stefan Hildenbrand
No - I am sorry. No news.
inlet, ramp, unsteady b.c.
VOF Inlet condition Rizwan FLUENT 15 July 5, 2018 17:33
unsteady inlet velocity udf jill FLUENT 8 February 10, 2015 07:04
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 13:41
unsteady state inlet boundry condition shubham FLUENT 3 March 1, 2009 09:34
transitional inlet boundary condition kamp CFX 1 June 21, 2006 12:08
