Adding new term in to K eqn of K-Epsilon turbuelnce model |
October 9, 2012, 06:29 |
Adding new term in to K eqn of K-Epsilon turbulence model
OpenFoam
Rep Power: 14 |
Hi all,
i have made a copy of existing kepsilon model and renamed as mykEpsilon. Now i want to add compressibility correction factor Ym=2*epsilon*(M^2) ,where M=sqrt(k/(a^2)) in to the k equation. Now i have to define a new dimensioned scalar constant "a" (velocity of sound= 350 m/s). can someone help me in doing this? how should i define "a"? where should i give its dimension? etc.. Plz help..! Last edited by neeraj; October 10, 2012 at 06:01. |
October 10, 2012, 02:44 |
My try...!
OpenFoam
Rep Power: 14 |
I tried by adding these lines to mykEpsilon.C
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // airvel_ ( dimensioned<scalar>::lookupOrAddToDict ( "airvel", coeffDict_, //added by me // 117649 ) ), // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // and by adding these line to mykEpsilon.H class protected data // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensionedScalar airvel_; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Also added the dimensions into transportproperties in the pitzDaily/Constant // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // transportModel Newtonian; nu nu [ 0 2 -1 0 0 0 0 ] 1e-05; airvel_ airvel_ [ 0 2 -2 0 0 0 0 ] 117649; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // But i am getting error as follows::: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model mykEpsilon mykEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; airvel 117649; } Defining my own kEpsilon model No field sources present SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0606635, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0316293, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00922589, No Iterations 161 time step continuity errors : sum local = 0.58783, global = -0.001983, cumulative = -0.001983 DILUPBiCG: Solving for epsilon, Initial residual = 0.225166, Final residual = 0.0179849, No Iterations 1 --> FOAM FATAL ERROR: incompatible dimensions for operation [k[0 2 -3 0 0 0 0] ] - [k[0 4 -5 0 0 0 0] ] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/fvMatrix.C at line 1316. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::fvMatrix<double> const&, char const*) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #3 at mykEpsilon.C:0 #4 Foam::incompressible::RASModels::mykEpsilon::corre ct() in "/home/http/OpenFOAM/http-2.1.1/platforms/linux64GccDPOpt/lib/libmyTurbulenceModels.so" #5 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/simpleFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/simpleFoam" Aborted (core dumped) |
October 10, 2012, 02:45 |
new k-eqn
OpenFoam
Rep Power: 14 |
// Turbulent kinetic energy equation
tmp<fvScalarMatrix> kEqn ( fvm::ddt(k_) + fvm::div(phi_, k_) - fvm::Sp(fvc::div(phi_), k_) - fvm::laplacian(DkEff(), k_) == G - fvm::Sp(epsilon_/k_, k_) - fvm::Sp(2*epsilon_/airvel_, k_) //***added Ym compressibilty effect***// ); |
October 11, 2012, 08:18 |
OpenFoam
Rep Power: 14 |
plz reply... if you want any more details please ask.... i think the basic problem is where to define the new variable "airvel"
Help regarding K Epsilon model | go2saqi | Main CFD Forum | 2 | January 23, 2012 12:59 |
Curvature Effects using the Standard K Epsilon Model | syler3321 | CFX | 2 | October 19, 2010 21:53 |
The effect of E term in the EPSILON equation | Valdemir G. Ferreira | Main CFD Forum | 6 | June 7, 2000 03:37 |
Extra term in Epsilon equation | Valdemir G. Ferreira | Main CFD Forum | 0 | April 30, 2000 09:57 |
bouyancy term in epsilon equation | Michael | Main CFD Forum | 1 | June 25, 1999 11:20 |
