September 28, 2012, 18:01 |
Nusselt number correlation problem
Rick Tejeda
Rep Power: 14 |
I'm trying to calculate the heat transfer through an enclosure similar to the buoyantCavity tutorial, but my results do not correlate well with literature. For example, the Nusselt number for an argon filled 1m x 1m x 12.7mm cavity with a dT of 29.1 degrees should be about 1.3 according to Wright (www.solarme.uwaterloo.ca/DownloadPDFs/ASHcornScan_acw.pdf), but I'm getting Nu = 1.1 with the attached model. Successive grid refinements don't significantly change the answer I'm getting. I think my problem is either with the BCs or the grid design, but nothing I try seems to help. Any suggestions for improving the correlation would be greatly appreciated.
Nusselt Number problem | Goutam | OpenFOAM Running, Solving & CFD | 5 | July 12, 2012 06:14 |
Problem in Nu number | Diana.N | FLUENT | 2 | March 2, 2012 07:18 |
Local Nusselt Number | rohangulavani | FLUENT | 0 | July 6, 2010 08:03 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Nusselt Number of the order of 35000 | chinmay | FLUENT | 4 | May 31, 2001 04:06 |
