dynamicMotionSolverFvMesh on one cellZone only |
September 27, 2012, 08:11 |
Stefan Sicklinger
Rep Power: 15 |
I would like to combine AMI and the dynamicMotionSolverFvMesh (displacementLaplacian) for FSI with rotating meshes. Is it possible to limit somehow the cellZone on which the displacementLaplacian is solving the mesh motion equation? Thanks for your comments in advance! |
October 30, 2012, 16:33 |
Kanuk
Rep Power: 16 |
I'm also interested in this topic.
Anyone out there have any success (or failures) with ami (or ggi) for FSI with rotating meshes? |
October 31, 2012, 03:58 |
Hrvoje Jasak
Rep Power: 33 |
We have done a wind turbine with FSI for a blade: you will have to write your own dynamic mesh class for this.
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
June 2, 2020, 10:13 |
Similar issue
Conor
Rep Power: 10 |
Hi Guys,
In the 8 years since this thread was started, has the ability to apply the displacementLaplacian on one cellZone only been implemented? I am trying to model a VAWT blade and its deflections using Calculix. When combining solidBody motion with displacementLaplacian I get an error where the rotating body shrinks to a point where the simulation fails (see attached image). Is there any way around this? Thanks, Conor |
February 28, 2021, 19:49 |
#5 | |
Cyrille Bonamy
Rep Power: 11 |
I have similar issue, with similar problem (oscillating blade and its deflections using Calculix via precice). Did you solve the problem? |
pointZone to cellZone | Peter_600 | OpenFOAM | 5 | July 17, 2012 04:33 |
[mesh manipulation] Selecting cellzone using cellSet in OpenFOAM-1.7.0 | ggoggodak85 | OpenFOAM Meshing & Mesh Conversion | 0 | April 25, 2012 06:48 |
porous media (cellzone) | thisisit | FLUENT | 1 | November 24, 2011 04:32 |
How to compute cellZone volume | vinz | OpenFOAM Programming & Development | 11 | August 2, 2010 18:38 |
[snappyHexMesh] How can I put snappy layers in a separate cellzone? | overkligheten | OpenFOAM Meshing & Mesh Conversion | 1 | April 5, 2010 10:18 |
