parallel computing with GGI (OF 1.6 extend)
Old   September 26, 2012, 03:41
Exclamation parallel computing with GGI (OF 1.6 extend)
Andreas Wendy
A.Wendy is on a distinguished road
Hi everybody,
i am working on a calculation with OF 1.6 extend and a rotating mesh with using GGI and pimpleDyMFoam.
When i try to use a parallelisation of the calculation i get several errors:
i am using mpi run for the parallel computation
For the GGI i set the "bridgeOverlap" to true for the parallel run.
log.decomposePar - not sure if this is an error or a warning only...
Processor 1: field transfer
Initializing the GGI interpolator between master/shadow patches: outsideSlider/insideSlider
From function void GGIInterpolation<MasterPatch, SlavePatch>::rescaleWeightingFactors() const
in file /home/subuntu/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/GGIInterpolationWeights.C at line 544
Uncovered faces found. On master: 0 on slave: 98
log.mpirun - same as above (warning or error?)
Selecting dynamicFvMesh mixerGgiFvMesh
Uncovered faces found. On master: 0 on slave: 28
log.reconstructPar (first i have the same problem as above but when it comes to the first calculated timeStep i got an Fatal error (very below)
Create mesh for time = 0
Time = 0.0001
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/subuntu/OpenFOAM/Projekte/Masterthesis/GGI/Flachprofil_pimpleDyMFoam/komplett/processor0/0.0001/polyMesh/pointProcAddressing at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
i attached the complete log-files below.
with regards
Andy
A.Wendy is offline   Reply With Quote
Old   November 18, 2012, 18:27
Atheendra
atheendra is on a distinguished road
Hi Andreas
I am working on simulating Vortex-induced-Vibrations of multiple cylinders using OpenFOAM 1.6.x and was trying to run the case in parallel. I gave the part of domain with GGi interfaces to a single processor.The case seems to run without any problem.However, reconstructPar doesn't work. It shows the following error message:
--> FOAM FATAL ERROR:
Problem with patch-to zone addressing: some patch faces not found in interpolation zone
From function void ggiPolyPatch::calcZoneAddressing() const
in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 92.
FOAM aborting
Can you please let me know what might be the problem that's causing this?
atheendra is offline   Reply With Quote
decompose, ggi, parallel, pimpledymfoam, reconstruct
Create a GeometricField of a given type on given patch? philippose OpenFOAM Programming & Development 4 August 12, 2013 13:41
GGI in Parallel error renyun0511 OpenFOAM Running, Solving & CFD 1 November 9, 2011 22:56
Performance of GGI case in parallel hannes OpenFOAM Running, Solving & CFD 26 August 3, 2011 04:07
Parallel Computing peter Main CFD Forum 7 May 15, 2006 10:53
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
