chtMultiRegionFoam, fixed convection coefficient between fluid and solid
Old   September 19, 2012, 15:43
Default chtMultiRegionFoam, fixed convection coefficient between fluid and solid
Romain
romain.h is on a distinguished road
I was wondering if I could use a fixed convection coefficient as a boundary condition.
Here is my simulation :
For now, I use
solid_to_air
type compressible::turbulentTemperatureCoupledBaffleMix ed;
value uniform 300;
neighbourFieldName T;
K solidThermo;
KName none;
as it is done in the tutorial chtMultiRegionHeater.
From what I understand, with this boundary condition, the coefficient of convection h is automatically calculated from the nature of the flow.
But is it possible to impose a value ?
I tried to use fixed gradient since Q=h*S*DT (q=h*DT, thus DT=q/h), but it does not seem to work.
If I use,
solid_to_air
type fixedGradient:
gradient 5;
and
air_to_solid
type fixedValue:
value uniform 300;
the gradient does not seem to be taken between the solid and the air, but between the two walls of the solid, and since one of the side of the solid is heated, the simulation does not reach convergence.
When I use solid_to_air : fixed value or type compressible::turbulentTemperatureCoupledBaffleMix ed; on both solid_to_air and air_to_solid
my simulation is working.
If it was an exterior wall, I could have use
type externalWallHeatFluxTemperature;
K solidThermo; // solidThermo or lookup
// q uniform 62500; // Heat flux / [W/m2]
Ta uniform 300.0; // Tambient temperature /[K]
h uniform 100.0; // Heat transfer coeff /[W/Km2]
value uniform 300.0; // Initial temperature / [K]
KName none;
But with this condition, Ta is fixed and does not use the value of Tair
Thanks in advance,
Romain
romain.h is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
solid to fluid heattransfer with chtMultiRegionFoam nakor OpenFOAM 11 March 21, 2011 09:28
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
