September 16, 2012, 06:14 |
isothermal solution of chtMultiRegionFoam
Pierre
Rep Power: 15 |
I am running a simple 2D problem with chtMultiRegionFoam. On the bottom of the domain, I have a thiner solid region. On top, a air region with air flowing on the solid. First, I would like to test the isothermal problem. I set ALL my boundary conditions to: T=300. On the postproc, I checked that at time=0 I have everything at T=300. But during the solution, the temperature in the fluid domain raises! I don't know where this heat comes from since I have everything at the same temperature. Any idea? Attached image is the T field at the end of the solution. Thanks, pilafa |
October 1, 2012, 12:10 |
Rep Power: 14 |
hello,
have you tried a more densed mesh? or a low maximum Courant number (/lower timestep)? ciao |
chtmultiregionfoam, temperature |
Integrated conjugate heat transfer solver in OpenFOAM | hjasak | OpenFOAM Running, Solving & CFD | 172 | April 13, 2023 01:42 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 22:22 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Mesh independent solution | CFX Begineer | CFX | 0 | October 27, 2002 11:54 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
