chtMultiRegionFoam, error while when defining the thermodynamic properties |
September 12, 2012, 16:22 |
Romain
Rep Power: 16 |
I seem to have an error while defining my fluid thermophisycal properties. Code:
Adding to thermoFluid Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 *Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 * in "/lib/x86_64-linux-gnu/libc.so.6" #3 *Foam::hsRhoThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so" Code:
thermoType hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>; mixture { specie { nMoles 1; molWeight 28.9; } thermodynamics { Cp 1000; Hf 0; } transport { mu 1.8e-05; Pr 0.7; } } // ************************************************************************* // So I guess that hRhoThermo... is using a constant which is null and ill defined but I can not find which one. Any idea of where I should be looking ? I can run the tutorial with the same law (hRhoThermo<pureMixture...), so something is wrong with one of my boundary condition, or constant file. I did copy the whole tutorial chtmultiregionsimplefoam, and then I replaced the polymesh folder, and run my own blockMesh, snappyhexmesh, toposet, and splitMeshRegion. Thanks in advance, Romain |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
defining volume properties via UDF | Ralf Schmidt | FLUENT | 0 | July 17, 2006 11:30 |
