August 29, 2012, 07:54 |
cyclicAMI for non matching geometry?
Thomas
Rep Power: 14 |
Hello Foamers
If I am not mistaken cyclicAMI can be used to make two independently meshed and moving areas interact with each other. (As seen in the ship's propeller tutorial) My question: Is it possible to connect two meshes which do not match geometrically? E.g. consider two boxes on top of each other. The upper one like three times the size of the lower one and sliding on top of it. Any help/comment/discussion would be greatly appreciated. Best, Thomas |
August 30, 2012, 09:40 |
Thomas
Rep Power: 14 |
PS: A competent 'no' would also be a valuable answer...
August 30, 2012, 13:42 |
#3 | |
Attesz
Rep Power: 17 |
It is not possible to do currently, maybe you should try 1.6-ext, but I'm not familiar with the features of that code. I had a simulation where only a half cell was non-overlapped with the other side, and the simulation stopped. Hopefully, OpenCFD will improve this very soon. Best, Attila |
August 30, 2012, 13:51 |
Hannes Kröger
Rep Power: 18 |
You could try the "stitchMesh" tool to connect the grids.
August 30, 2012, 13:52 |
Attesz
Rep Power: 17 |
he want's to do moving on the connecting surfaces as I understood. stitching the mesh doesn't help unfortunately.
September 3, 2012, 05:15 |
Thomas
Rep Power: 14 |
Thank you very much, Attila and Hannes!
So it is not possible to move the meshes relative to each other. :-( Is there a way to define the translation of the boundaries and 'remesh' the entire mesh if neccessary? I think mesh deformation only will not be sufficient in my case because i need an obstacle to be sliding over the ground and then hovering over a channel and continue sliding on the other side's ground. Best, Thomas |
September 3, 2012, 05:30 |
#7 | ||||
Attesz
Rep Power: 17 |
September 3, 2012, 06:47 |
Hannes Kröger
Rep Power: 18 |
I haven't used it myself, but there should be the sliding mesh interface. stitchMesh is essentially a frontend for this machinery but I think it can be used standalone as well. Regards, Hannes |
cyclic boundary, moving mesh |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
[DesignModeler] Error while Loading a Geometry | JD944 | ANSYS Meshing & Geometry | 0 | October 25, 2011 14:51 |
[Gmsh] Problem meshing an imported geometry | Alicia | OpenFOAM Meshing & Mesh Conversion | 0 | March 30, 2010 04:53 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
