August 28, 2012, 08:17 |
[chtMultiRegionFOAM] Convergence
M
Rep Power: 14 |
I'm actually running a case, using a kind of chtMultiRegionFOAM, just a bit modified (orthotropic definition of material). I don't understand the mean of convergence we have, and the meaning of the timeStep in controlDict. I explain : If I put 0.0001 for a timeStep, it's EXACTLY the same, when I post process, as if I put 10000 for a timeStep. It's juste ONE timeStep. So, in my case, I've got two solids and a fluid. The residuals of the fluid converge very quikly (see graph). But the temperature of my solid (Box2) is VERY VERY nit (4 hours with 4 processors => 8000 timeSteps) (See graph). And I don't understrand physically why.... EDIT : Ok, I found a solution : Put T relaxation to 1.0 (It was 0.7 before). 32 times faster. Have a good day, Best regards, m_f Last edited by m_f; August 28, 2012 at 09:43. |
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 11:55 |
Defect correction and convergence | ganesh | Main CFD Forum | 4 | June 30, 2006 15:20 |
