sprayFoam BC for flow with dispersion
Old   August 23, 2012, 08:17
Default sprayFoam BC for flow with dispersion
Robert
vainilreb is on a distinguished road
Hey,
I set up a case with a small ammonia cloud in a room with an air inlet and an air outlet. The simulation runs for a few steps and then the gas temperature difference increases unreasonably fast. Maybe you can tell me why?
| \\ / O peration | Version: 1.4 |
| \\ / A nd | Web: http://www.openfoam.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class volScalarField;
object p;
dimensions [ 1 -1 -2 0 0 0 0 ];
internalField uniform 101300;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 101300;
walls
type zeroGradient;
empty
type zeroGradient;
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class volVectorField;
object U;
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform ( 0 0 0 );
boundaryField
inlet
type fixedValue;
value uniform ( 1 0 0 );
outlet
type zeroGradient;
walls
type fixedValue;
value uniform ( 0 0 0 );
empty
type zeroGradient;
I just a second the temperature difference increases from zero to more than 100 K... I think it's got something to do with the inlet and outlet BC. But I'm not sure WHAT.
Thanks a lot.
Robert
vainilreb is offline   Reply With Quote
Old   August 24, 2012, 04:17
Robert
No idea, anyone? Changed the BC from fixedValue to inletOutlet, tried to set up fixed outlet speed and pressure-controlled inlet flow and still got the same problem.
sprayFoam crashes lukasfischer OpenFOAM Running, Solving & CFD 3 July 14, 2013 12:08
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 13:00
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 24, 2010 00:56
Question on Dispersion Mike Marcu FLUENT 2 September 14, 2005 20:53
Heavy Gas Dispersion Roued Main CFD Forum 1 December 17, 2001 04:10
