calling Janaf coeff
Old   August 13, 2012, 16:20
Post calling Janaf coeff
sebastien vilfayeau
sebastien_F1 is on a distinguished road
I'm working on fireFoam, OpenFoam and I try to implement a new model. For this model, I need to have access to polynomial Janaf coefficients defined in "constant/thermo.compressibleGas".
My solution was to use a dynamic cast inside my code as follows :
const specieThermo<janafThermo<perfectGas> >& janaf_
dynamic_const<const specieThermo<janafThermo<perfectGas> >&>(thermo_)
And after to call those coefficients with member functions in janafthermo, which are lowCpcoeffs and highCpcoeff.
For example : janaf_.lowCpcoeffs()
When I compile my code, I have no errors, but when I run the code I have a bas cast error ( std::bad_cast)
I don't know how to solve this problem,. If you have any idea you're welcomed.
thanks
sebastien
sebastien_F1 is offline   Reply With Quote
janafthermo, openfoam, polynomial, thermo
Newer Janaf Model iyer.arvind OpenFOAM 43 October 28, 2020 07:26
absorption coeff. for radiation yugo_wen STAR-CCM+ 0 June 1, 2010 11:25
Low temp. (~ 300 K) turb. jet & JANAF problems bart_weisser OpenFOAM Running, Solving & CFD 0 February 11, 2010 19:50
Material properties:absoption and scattering coeff Novice FLUENT 0 December 4, 2008 03:21
JANAF tangd OpenFOAM Running, Solving & CFD 12 July 26, 2006 05:26
