snappyHexMesh in parallel - FOAM Fatal IO Error |
August 9, 2012, 21:07 |
Marco A. Turcios
Rep Power: 28 |
Hello Forum,
I've been trying to run snappyHexMesh to work in parallel, and I keep getting the following error, always right after "Remove unreachable sections of mesh": [2] [2] [2] --> FOAM FATAL IO ERROR: [2] error in IOstream "IOstream" for operation operator>>(Istream&, List<T>&) : reading first token [2] [2] file: IOstream at line 0. [2] [2] From function IOstream::fatalCheck(const char*) const [2] in file db/IOstreams/IOstreams/IOstream.C at line 114. [2] Its similar to this orphaned bug report about OpenMPI versions: http://www.openfoam.org/mantisbt/view.php?id=370 Has anyone run across this. It seems like I may be missing something simple in the setup, but nothing I've read in the threads gives me any clue. Thanks! |
August 9, 2012, 21:33 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Marco,
I haven't seen anything on this yet. So this would be a great opportunity to start figuring out what makes this bug happen So, a few questions help start the diagnosis process:
Bruno
August 10, 2012, 14:27 |
Marco A. Turcios
Rep Power: 28 |
Hey Bruno, thanks for looking into this (are you on vacation again?)
I haven't run any other parallel snappyHexMesh cases; I'll have a look at the ones you recommended and get back to you. In the meantime I'll answer what I can: I am using OpenFOAM 2.1.x. I've used both simple and scotch decomposition methods into 6 subdomains. The full log of decomposition is (beginning right after patch selection) Code:
Added patches in = 0.23 s Selecting decompositionMethod simple Refinement phase ---------------- [1] Found point (0 0 -2) in cell 31806 on processor 1 Feature refinement iteration 0 ------------------------------ No cells marked for refinement since reached limit 300000. Determined cells to refine in = 0.79 s Selected for feature refinement : 0 cells (out of 630000) Stopping refining since too few cells selected. Surface refinement iteration 0 ------------------------------ No cells marked for refinement since reached limit 300000. Determined cells to refine in = 0.01 s Selected for refinement : 0 cells (out of 630000) Stopping refining since too few cells selected. Removing mesh beyond surface intersections ------------------------------------------ Found point (0 0 -2) in cell -1 in global region 1 out of 18 regions. Keeping all cells in region 1 containing point (0 0 -2) Selected for keeping : 44551 cells. Edge intersection testing: Number of edges : 150468 Number of edges to retest : 33104 Number of intersected edges : 21225 Shell refinement iteration 0 ---------------------------- Marked for refinement due to refinement shells : 0 cells. Determined cells to refine in = 1.14 s Selected for internal refinement : 0 cells (out of 44551) Stopping refining since too few cells selected. Splitting mesh at surface intersections --------------------------------------- Introducing baffles for 21225 faces that are intersected by the surface. Edge intersection testing: Number of edges : 171580 Number of edges to retest : 137163 Number of intersected edges : 42301 Created baffles in = 0.39 s After introducing baffles : cells:44551 faces:171580 points:61361 Cells per refinement level: 0 44551 Introducing baffles to block off problem cells ---------------------------------------------- markFacesOnProblemCells : marked 53912 additional internal faces to be converted into baffles. Analyzed problem cells in = 0.12 s Introducing baffles to delete problem cells. Edge intersection testing: Number of edges : 225492 Number of edges to retest : 177360 Number of intersected edges : 42304 Created baffles in = 0.39 s After introducing baffles : cells:44551 faces:225492 points:62596 Cells per refinement level: 0 44551 Remove unreachable sections of mesh ----------------------------------- Keeping all cells in region 22 containing point (0 0 -2) Selected for keeping : 14920 cells. Edge intersection testing: Number of edges : 48436 Number of edges to retest : 0 Number of intersected edges : 7026 Split mesh in = 0.19 s After subsetting : cells:14920 faces:48436 points:18808 Cells per refinement level: 0 14920 Handling cells with snap problems --------------------------------- Introducing baffles for 7026 faces that are intersected by the surface. Edge intersection testing: Number of edges : 48436 Number of edges to retest : 20701 Number of intersected edges : 7026 Created baffles in = 0.13 s After introducing baffles : cells:14920 faces:48436 points:18808 Cells per refinement level: 0 14920 Introducing baffles to block off problem cells ---------------------------------------------- markFacesOnProblemCells : marked 0 additional internal faces to be converted into baffles. Analyzed problem cells in = 0.05 s Introducing baffles to delete problem cells. Edge intersection testing: Number of edges : 48436 Number of edges to retest : 0 Number of intersected edges : 7026 Created baffles in = 0.06 s After introducing baffles : cells:14920 faces:48436 points:18808 Cells per refinement level: 0 14920 Remove unreachable sections of mesh ----------------------------------- [2] [2] [2] --> FOAM FATAL IO ERROR: [2] error in IOstream "IOstream" for operation operator>>(Istream&, List<T>&) : reading first token [2] [2] file: IOstream at line 0. [2] [2] From function IOstream::fatalCheck(const char*) const [2] in file db/IOstreams/IOstreams/IOstream.C at line 114. [2] FOAM parallel run exiting [2] Many thanks again! |
August 10, 2012, 14:33 |
#4 | ||
Bruno Santos
Rep Power: 128 |
Hi Marco,
But what about for running snappyHexMesh itself in parallel? I think "simple" will work with snappy, but "scotch" is a big no, you'll have to use "ptscotch". Best regards, Bruno
August 10, 2012, 20:18 |
#5 | |
Marco A. Turcios
Rep Power: 28 |
I tried using simple for both decomposition and snappy, as well as mixing and matching. I read about using 'ptscotch' with snappy that on a few threads but it hasn't fixed the problem. The parallel motorBike case works fine, I'm going to try using hierarchical like it and base my case on it as its probably the closest I can think of. I'll let you know what happens (after the weekend!) |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 05:53 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 18:43 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 16:46 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
