Disabling SIMPLE convergence check in simpleControl.H
Old   August 8, 2012, 18:31
Default Disabling SIMPLE convergence check in simpleControl.H
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
I'm trying to solve 5 equations, which 3 of them are getting solved as coupled and the rest of them are uncoupled (passive scalars). I have added 2 new equations to solve passive scalars into buoyantBoussinesqSimpleFoam. But when I start solving after some reasonable iterations solution stops solving and a messages comes up which says "SIMPLE solution converged in *** iterations". But when I post-process the case my 2 passive scalars haven't reached to steady state conditions. So I want to run case with more iterations.
I tried to find the source code which controls the convergence. the source solver code includes a header file:
#simpleControl.H
I found this file in here:
OpenFOAM-2.0.1/src/finiteVolume/cfdTools/general/solutionControl
inside simpleControl.H I found there is an another header file which controls convergence:
#include "simpleControlI.H"
I want to ask you how can I disable this? after removing the line which includes simpleControlI.H am I supposed to compile my own solver or any other thing at all or nothing will be done?
Any help would be appreciated. Regards,
Mojtaba ~
Mojtaba.a is offline   Reply With Quote
boussinesqsimple, convergence, simple, simplecontrol.h
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 18:02
the criterium of convergence for the SIMPLE algo Lam Main CFD Forum 1 July 25, 2007 10:08
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 07:06
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 15:20
SIMPLE for variable viscosity, poor convergence ? Anthony Ilaner Main CFD Forum 15 July 13, 2000 09:04
