--> FOAM FATAL ERROR: Maximum number of iterations exceeded
Like Tree3Likes
Old   December 5, 2014, 13:36
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Originally Posted by slash89 View Post
Hi all,
i got the same problem. I am using the buoyantSimpleRadiationFoam. The problems is always at the second time step, when solving the G file. Any suggestions to fix this problem?
Thank you,
Best regards
Greetings slash89,
please attach your log file, in this way we can help you much more easily
adambarfi is offline   Reply With Quote
Old   December 5, 2014, 14:05
slash89 is on a distinguished road
Here is the log file. I am sorry but i could not upload the file and i don't know why!
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : buoyantSimpleRadiationFoam -parallel
Date : Dec 05 2014
Time : 18:58:35
Host : "millegradi-nb"
PID : 4112
Case : /home/bolzo/TERMIGNONI/run/prove_solver/prova_5
nProcs : 4
Slaves :
3
"millegradi-nb.4113"
"millegradi-nb.4114"
"millegradi-nb.4115"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 -0.33;
sigmak 1;
sigmaEps 1.3;
Prt 1;
Calculating field g.h
Reading field p_rgh
Selecting radiationModel P1
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel constantScatter
SIMPLE: convergence criteria
field p_rgh tolerance 0.01
field U tolerance 0.001
field h tolerance 0.001
field G tolerance 0.001
field "(k|epsilon|omega)" tolerance 0.001
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00766817, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.00749132, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.00791072, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.00766938, No Iterations 1
DICPCG: Solving for G, Initial residual = 1, Final residual = 0.096472, No Iterations 335
DICPCG: Solving for p_rgh, Initial residual = 0.999948, Final residual = 0.00829887, No Iterations 450
time step continuity errors : sum local = 0.145697, global = -0.0018876, cumulative = -0.0018876
rho max/min : 79.6338 1.1739
DILUPBiCG: Solving for epsilon, Initial residual = 0.12008, Final residual = 0.00390459, No Iterations 1
bounding epsilon, min: -5.64769 max: 1881.23 average: 13.0219
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0865008, No Iterations 1
ExecutionTime = 23.58 s ClockTime = 23 s
Time = 2
DILUPBiCG: Solving for Ux, Initial residual = 0.998573, Final residual = 0.0137559, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.999799, Final residual = 0.0141418, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.999881, Final residual = 0.0139621, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.013323, No Iterations 1
Thak you!
slash89 is offline   Reply With Quote
Old   December 5, 2014, 14:29
adambarfi's Avatar
Mostafa Mahmoudi
Are you sure about the BCs you exerted on your geometry? and I wanted the log file not the fist two iteration log
it seems that your cumulative time step error will grow up and the range of rho variation I think is very much!!!
if you're sure about the BCs, then you should check your schemes.
Old   December 5, 2014, 15:06
Sorry but i don't understand which file you need. Do you need the G file?
Best regards
Old   December 5, 2014, 15:34
adambarfi's Avatar
Mostafa Mahmoudi
just run your case and get the log file:
solverName >log
and the errors appeared in your terminal.
such as: http://www.cfd-online.com/Forums/ope...tml#post375086
Old   December 5, 2014, 16:14
[2] Maximum number of iterations exceeded
[2]
[2]     From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const
[2]     in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 69.
[2]
FOAM parallel run aborting
[2]
[2] #0  Foam::error::printStack(Foam::Ostream&)[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Maximum number of iterations exceeded
[0]
[0]     From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const
[0]     in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 69.
[0]
[0]
[0] #0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #1  Foam::error::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1  Foam::error::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #2  Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::T(double, double, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2  Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::T(double, double, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const, double (Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> >::*)(double) const) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
[2] #3  Foam::hPsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
[0] #3  Foam::hPsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
[0] #4   in "/opt/openfoam2Foam::hPsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::correct()11/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
[2] #4  Foam::hPsiThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::correct() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
[0] #5   in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
[2] #5
[0]  in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/buoyantSimpleRadiationFoam"
[0] #6  __libc_start_main[2]  in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/buoyantSimpleRadiationFoam"
[2] #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #7   in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #7
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 0 with PID 2812 on
node millegradi-nb exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[millegradi-nb:02811] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[millegradi-nb:02811] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Hope this is what we need!
Old   December 6, 2014, 02:13
adambarfi's Avatar
Mostafa Mahmoudi
The problem is probably related to the pressure field. I guess you have negative pressure, so the thermophysical library crashes.
check the following:
  1. check your grids, checkmesh
  2. use 1st order scheme for temporal discretization
  3. modify the tolerance tol_ from 1.0e-4 to something higher e.g. 1.0e-3, but this is not a good advice. thanks to dmoroian
  4. at last, modify the maxIter_ from 100 to something larger. you can find the implementation process in http://www.cfd-online.com/Forums/ope...tml#post179437
hope these help you
Old   December 6, 2014, 05:59
It still does not work. At this point the problem is in the BCs. Can I upload them here?
Old   December 6, 2014, 06:13
adambarfi's Avatar
Mostafa Mahmoudi
it's the best thing you can do!
Old   December 6, 2014, 06:17
0.tar.gz
Thak you!
Old   December 9, 2014, 07:15
nobody can help??
Old   April 4, 2016, 10:35
Default Maximum number of iterations exceeded
  #32
masoudsh is on a distinguished road
hi
i have this problem
can anyone help me?
if i change the mesh ,solve?
or if i remove the energy equation
best regards
masoud
in file /home/opencfd/OpenFOAM/OpenFOAM-2.0.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 67.
masoudsh is offline   Reply With Quote
Old   April 5, 2016, 18:27
Derek Mitchell
derekm is on a distinguished road
Need a lot more info
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   April 5, 2016, 18:32
hi Derek
what do you want to know?
did you see this problem later?
best regards
masoud
Old   April 27, 2016, 07:43
Hi
I got the sam problem,Can anyone solve it?
I have this problem in my project,I do anything such as mesh,Bc , ... but doesn't work.
if I find anything tell here ,please help me if the problem solve
Best Regards
Masoud
Old   April 27, 2016, 09:55
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Originally Posted by masoudsh View Post
Hi
Best Regards
Masoud
Hi Masoud,
Take a look at this:
http://openfoam.ir/questions/questio...AE%D8%B7%D8%A7
Best.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) Scabbard OpenFOAM Running, Solving & CFD 1 July 22, 2014 05:50
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
