nutkRoughWallFunction in turbineSiting
Old   August 2, 2012, 00:06
Default nutkRoughWallFunction in turbineSiting
hfs
hfs is on a distinguished road
Hello!
I am using the turbineSiting tutorial to help me understand how to implement a rough wall boundary conditions
I tried to change the Ks value in the nut file in 0 folder from 0.2 to 200 ,,, but it is giving me the same velocity field every time ... is this nutkRoughWallFunction really working??
Please see the attached photos!
Thanks a lot for your explanation!
hfs is offline   Reply With Quote
Old   November 15, 2014, 06:42
zandi's Avatar
Fatema Zandi Goharrizi
zandi is on a distinguished road
Originally Posted by hfs View Post
Hello!
I have the same question
zandi is offline   Reply With Quote
Old   November 15, 2014, 06:47
Retired Super Moderator
Bruno Santos
Greetings to all!
Which OpenFOAM version are you using? It's indeed possible that this is a bug and it also might have already been fixed in more recent versions.
Best regards,
Bruno
Old   November 16, 2014, 08:18
zandi's Avatar
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Thank you very much it was my fault. but now I have another problem. due to maning formula the water level has been compared to simulated water level.
but there is a big difference.
Maning formula --> y0=0.0429
simulated ----> y0=0.058
OpenFOAM 2.3.0
solver=interFoam
n(maning)=0.011 ----> Ks=0.3 mm
Cs=0.5
s=tan 2.5
L=2mm
q=0.1 m^3/s/m
is there any reason?
Regards,
zandi
Old   November 16, 2014, 16:03
Bruno Santos
Hi zandi,
Sorry, I'm not familiar with this topic and therefore have no idea in what context those parameters are applied I don't know or at least don't remember reading about the "Maning formula".
I need more details on how those values are being used in your case in OpenFOAM, so that I can check if there is something wrong with the units used in "nutkRoughWallFunction".
In addition: please keep in mind that I can't see what you're seeing, unless you share it. See the following thread for checking what kind of information I'm looking for: http://www.cfd-online.com/Forums/ope...-get-help.html
It's also possible that you're using incorrect boundary conditions.
Best regards,
Bruno
Old   November 17, 2014, 03:33
zandi's Avatar
Thank you Bruno.
Maning formula give us the water level according to roughness and I want to compare my simulation result with that.
The domain is 2D and 1 or 2 mm cell size. Slope is 0.04366.
I give Ks=0.0003 m and Cs=0.5 to OF.
I set water fields and give volume inflow rate (Q/b=0.1m^3/s/m) in include folder (initial condition). K-Epsilon is used.
in case with no roughness water level has been obtained 56 mm and with roughness 58 mm
But it has to bee about 43 mm
BCs are:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
#include "include/initialConditions"
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
w-inlet
type variableHeightFlowRateInletVelocity;
flowRate $inletFlowRate;
alpha alpha.water;
value uniform (0 0 0);
outlet
type zeroGradient;
walls
type fixedValue;
atmosphere
type pressureInletOutletVelocity;
phi phi;
"(defaultFaces|Front|Back)"
type empty;
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform $pressure;
boundaryField
w-inlet
type zeroGradient;
outlet
type zeroGradient; }
walls
type zeroGradient;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho none;
psi none;
gamma 1;
value uniform $pressure;
type empty;
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
w-inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
walls
type nutkRoughWallFunction;
value uniform 0;
Ks uniform 0.0003;
Cs uniform 0.5;
atmosphere
type calculated;
value uniform 0;
type empty;
FoamFile
version 2.0;
format ascii;
object alpha.water;
dimensions [0 0 0 0 0 0 0];
boundaryField
w-inlet
type variableHeightFlowRate;
lowerBound 0.0;
upperBound 0.9;
value uniform 0;
outlet
type zeroGradient;
walls
type zeroGradient;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
type empty;
Old   November 17, 2014, 05:59
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Zandi,
Manning's equation is valid for uniform steady flow. Are you sure that the length of the channel is adequate for the flow to become uniform?
And about the simulation time, is it enough for the flow to become steady?
You are doing an interesting simulation. If you could send the complete setup of the case, I would be interested.
Best Regards,
Paulo
vatavuk is offline   Reply With Quote
Old   November 17, 2014, 11:47
zandi's Avatar
Originally Posted by vatavuk View Post
Hi Zandi,
Best Regards,
Paulo
Hi friend thank you
you are right.
But the simulation had got steady before I took the result data. and almost uniform!!
even though
I have done the calculation with simple step by step method too and in that length with start water level as the simulation 0.055 m, water level has been obtained 0.0446! and when it reached to almost uniform level is 0.0477 (with difference less than 0.001 in 0.2 meter distance of channel) and 0.304 (with difference less than 0.0001 in 0.2 meter distance of channel) and as you can see it is different with simulation too.
There is no more especial specification about simulation.
sorry for not sending complete case, it is my little project. but you can do it with what I explained in the post
Old   January 25, 2015, 12:43
Bruno Santos
Greetings to all!
@zandi: I've finally managed to come back to your question... but unfortunately I do not have enough time to set-up a case similar to yours.
If you're still interested to find the solution for this issue, then please provide a simple test case, because I don't have enough free time to prepare one myself; nor was I able to figure out what might be wrong, only by looking at the files you've provided.
Best regards,
Bruno
Old   January 25, 2015, 13:41
zandi's Avatar
Dear friends specially Bruno,
thanks for help,
I think I found the answer but forget to post here. It is because of not getting uniform as our fiend said.
however actually I expect when I give the uniform depth at inlet, it has to be uniform. but it seems it can't be so and need to get uniform at a length more than previous length I had given. why it is like that ?
I will send the simple case next time I'd log on.
Regards,
zandi
New! Turbinesiting tutorial bathgooner OpenFOAM Pre-Processing 7 July 29, 2021 00:52
SimpleWindFoam TurbineSiting atmBoundaryLayerInletVelocity Jochem OpenFOAM 17 May 9, 2017 06:54
Using turbineSiting Tutorial for a 2D model bathgooner OpenFOAM Running, Solving & CFD 0 March 14, 2012 14:35
