Outlet boundary condition for a heated tube flow
Old   July 28, 2012, 04:56
Default Outlet boundary condition for a heated tube flow
Jinbiao Xiong
JinBiao is on a distinguished road
Send a message via MSN to JinBiao
Dear All,
I am calculating the flow in a tube with the wall heated. The fluid property, including density, varies strongly with temperature change. So the flow at the outlet apparently deviates from the fully developed condition. The calculated radial velocity at outlet is given in the attached figure. With non-zero radial gradient of radial velocity, the zerogradient boundary condition at the outlet leads to poor continuity convergence. Also the streamwise velocity (see attached file) is distorted at the outlet compared with the upstream profiles due to the application of zerogradient boundary condition for velocity.
Is there any boundary condition type in OpenFOAM can avoid this problem?
Thanks for any discussion.
Jinbiao
JinBiao is offline   Reply With Quote
outlet boundary condition for two-phase flow Andrea1984 FLUENT 0 June 21, 2012 07:34
How to set the Heat Flux boundary condition at Outlet creddy_trddc CFX 3 September 21, 2011 08:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Boundary condition for not fully-developed flow John FLUENT 0 July 15, 2005 08:07
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
