September 4, 2017, 08:53 |
#21 |
Ashok
Rep Power: 9 |
Hi Lousi,
Thanks for coming back Yes I m using OF4.1. There were no errors. And Yes I have specified type in U file.Actually why I have asked the above question is I wanted to apply partialSLip to moving wall but not slip to moving wall. First I wanna know how to apply partialslip condition to moving wall. Is that possible in OF. I have applied like below, type partialSlip; value uniform (0 -0.5 0); valueFraction 0.4; But moving wall is not taking any velocity specified. (0 -0.5 0). Thank you. |
September 5, 2017, 04:40 |
#22 |
Not sure my boundary condition can deal with partialSlip as I have never dealt with it.
-LouIs |
September 5, 2017, 04:43 |
#23 |
Ashok
Rep Power: 9 |
September 5, 2017, 05:07 |
#24 |
Ashok, it might be an interesting problem but it is out of my scope. I suggest you start a thread if you are looking for such support.
September 5, 2017, 05:11 |
#25 |
Ashok
Rep Power: 9 |
Ok Louis. I have already posted a new Thread two weeks back. Still waiting for appropriate Response.
Anyway Thanks for your Time |
September 3, 2018, 04:58 |
#26 |
Helvines Aquino
Rep Power: 10 |
Hi Louis,
I'm interested in implementing you BC code. However, there's something I don't understand due to the lack of OF experience. If I copy it into my personal src directory, do I have to call it in the solvers' main source code and Make/options (as FOAM_USER_LIBBIN) that I want this BC to be applied (e.g interDyMFoam) and do I have to re-compile interDyMFoam solver again? |
September 3, 2018, 05:17 |
#27 | |
Hi Helvines,
You do not have to recompile the solver, you'll have to add something like this to controlDict: Quote:
https://github.com/louisgag/OpenFOAM...aster/testCase Kind regards, -Louis |
April 9, 2021, 01:48 |
#28 |
Huynh Phong Thanh
Rep Power: 13 |
Hi Louis,
I want to try your movingwallslip with table value as time-varying BC. But it only allows set uniform value. Should it combine two BCs uniformFixedValue with movingwallSlip? Because uniformFixedValue has table time varying value, but it is not moving wall. I want a BC applied for wall with moving in time, using interDymFoam 4.x solver. Do you have idea for this type BC? Kind regards |
April 9, 2021, 11:24 |
#29 |
Hi Huynh,
the BC I posted already computes the moving wall velocity, you don't need to use the timeVarying condition on top of it. Kind regards |
April 22, 2021, 23:27 |
#30 |
Huynh Phong Thanh
Rep Power: 13 |
Hi Louis,
Thank your reply. I want to set wall moving in time like this |
April 22, 2021, 23:28 |
#31 |
Huynh Phong Thanh
Rep Power: 13 |
Hi Louis,
Thank your reply. I want to set wall moving in time like this Code:
type uniformFixedValue; uniformValue table ( (0 (0 0 0)) (0.2 (1.5 0 0)) (0.4 (2.6 0 0)) (0.6 (3.48 0 0)) (0.8 (3.95 0 0)) (0.9 (4.12 0 0)) (1 (4.1 0 0)) (1.1 (-0.125 0 0)) (1.2 (-1.25 0 0)) (1.4 (1.1 0 0)) (1.45 (0 0 0)) (1.5 (-0.52 0 0)) (1.55 (-0.5 0 0)) (1.6 (-0.1 0 0)) (1.7 (0.6 0 0)) (1.75 (0.62 0 0)) (1.8 (0 0 0)) (2 (0 0 0)) (200 (0 0 0)) ); value $initialField; |
November 28, 2021, 09:46 |
#32 |
irwin
Rep Power: 12 |
Hi Louis,
I am using openfom8 , I have complied your code successfully without any error however when i apply it in my U file it is showing error : --> FOAM FATAL IO ERROR: Unknown patchField type myMovingWallSlip for patch type wall kindly help Thanks, Irwin |
November 29, 2021, 03:48 |
#33 |
Hi, you probably did not load the library you compiled.
Try correcting your controlDict accordingly. |
November 29, 2021, 12:36 |
#34 |
irwin
Rep Power: 12 |
Thanks a lot.
its working now |
December 1, 2021, 22:12 |
#35 | |
mohammad
Rep Power: 12 |
Sorry for my basic questions. I can't understand something in this type of Boundary conditions. It is still stress-free (zero gradient tangential velocity), but with a desired velocity value? I mean the moving wall condition is only implemented on both tangential and normal velocities or only the tangential velocity? Second thing is the boundary type for that. Is this a patch type or wall type? Cheers, Mohammad |
December 1, 2021, 23:37 |
#36 |
irwin
Rep Power: 12 |
Hi Louis,
how to introduce slip when wall is already moving with some velocity ( couette flow) ? Thanks, Irwin |
free slip wall, moving wall, moving walls |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
wall slip law for newtonian fluid | tsi07 | FLUENT | 0 | April 19, 2012 13:13 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
Stationary wall and Moving wall | Sri | FLUENT | 1 | July 29, 2008 05:33 |
Pressure on the free slip wall | yliu | CFX | 5 | March 30, 2007 04:47 |
