Stainless steel balls with icoUncoupledKinematicParcelFoam ?
Old   July 18, 2012, 04:16
Default Stainless steel balls with icoUncoupledKinematicParcelFoam ?
Vincent RIVOLA
vinz is on a distinguished road
Hi all,
Just for fun I had a look at the hopper tutorial of icoUncoupledKinematicParcelFoam.
I was wondering if it would be possible to simulate a similar case with some small stainless steel balls?
I have no experience in this field so I am not sure what I should modified to be able to run such simulation.
vinz is offline   Reply With Quote
Old   July 19, 2012, 03:12
Vincent RIVOLA
I manage to run a case. But it's not exactly doing what I want.
I saw that in hopperInitialState, the balls are initially placed according to a file named "kinematicCloudPosition". My problem is how can I generate this file automatically ? Because so far, I used the file from the tutorial which is done for balls of 6mm while in my case they are only 2mm.
My second problem is with the visualisation. I use glyphs in Paraview in order to visualise my cloud. The problem is that if I put the correct size for my balls (1mm radius) it looks like the balls are not touching each other. I have to use a size of 3cm for the radius which is not realistic. What do you think?
Old   July 19, 2012, 13:31
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
A quick and dirty solution that I've used for stuff like this is create a script in matlab. It'd be easy enough through nested for- loops, incrementing your x, y and z coordinates as needed based on the extent of the domain. Adapt something like this, only for vectors:
http://www.dreamincode.net/forums/to...hristmas-tree/
Maybe store these vectors in an array and then output them in a file with the parentheses and newlines. You'll need to add an openfoam header as well. You could probably also write this IN c++ with openFoam, which may take a little longer but might be a worthwhile excercise depending on what you'd like to do in the future.
mturcios777 is offline   Reply With Quote
Steel tube filled with concrete lookic ANSYS 0 June 17, 2012 06:48
[ANSYS Meshing] help me for modal analysis of steel structure Eng medo ANSYS Meshing & Geometry 0 December 5, 2011 07:43
combustion of carbon and steel kimej FLUENT 2 July 21, 2004 14:36
spherical balls in water with free surface Karthick FLUENT 0 February 10, 2004 05:24
CFD Consultancy-Iron & Steel cfdmetal Main CFD Forum 1 May 3, 2002 09:35
