scalarTransportFoam erased my original data and has very slowly transport results |
July 16, 2012, 18:10 |
Roro Wang
Rep Power: 16 |
Hi foamers,
I used other solver (e.g. pisoFoam) to generate a series of velocity fields. Then, I wanted to use scalarTransportFoam to calculate the scalar transport by the given velocity fields. So I just simply type scalarTransportFoam after setting up BC for T in 0 directory and adding DT in transportProperties, as well as some more corresponding modification in the fvSolution and fvSchemes to make it run. It runs without error, but my original U data has been replaced by the U file in 0 directory and the transport is actually slow, which looks like the U is not read in at all. Could anybody help me? Thanks. foamWang |
October 30, 2013, 18:20 |
Vishal Achasrya
Rep Power: 15 |
I think starting the simulation from latestTime means that only the U from latestTime is used. But what if for every time-step, I want scalarTransportFoam to use the U from that time-directory that was obtained from a different simulation? Say I have time-directories 0, 0.1, 0.2 etc all with a U file in them for that time, then can i copy these to scalarTransportFoam and get it to use the U from that time if I set my time-step to 0.1 and startTime to 0? I would have to technically move the code block that reads U, into the time-loop in the solver code. But this should work right? Vishal |
October 31, 2013, 03:51 |
#4 | |
Lieven
Rep Power: 22 |
Hi Vishal
I would opt to include the scalar transport equation directly into U-field solver and solve the scalar transport on the fly. For 3 reasons: 1. It gives you more flexibility towards choice of time step in the scalar transport. 2. It will go faster than storing all U-field and reading them afterwards 3. You need far less storage space Cheers, Lieven |
